mechanical water pump v/s 850hp
Is anybody running a mechanical water pump with 800 plus hp, 14:1cr drag only ? What about with the electric drive motor?
tconnection- Posts : 866
Re: mechanical water pump v/s 850hp
I use the Meziere electric pump on my 557. I have used a stock pump with a Moroso elec. motor drive with O/D pulley on a 514 that made 725-750 hp.
BigDave65- Posts : 567
557 mazda runs one on his 557 bbf he has 14:5 cr works fine on his
ok thats great. I was thinking maybe a mechanical high volume pump with the electric drive motor. What do you think?
That is what I have on mine but it does not have that much compression it is only about 9:5 460 with dove-c heads with around 500 to 525 hp I have the larger drive pulley on mine witch turns the pump faster it runs around 190*.
Jim
Jim
