Question for Steve
Question for Steve Empty Question for Steve
Post  studly November 8th 2010, 5:00 pm
If you cannot leave on full NOS power Example pulling an extra 5 degrees of timing to keep car from spinning then ramping timing back in will the car run quicker with one kit on say 350hp ramping timing back in or leaving on one kit full power say 150 then bring in another kit for 200hp. about .6 into the run
also which kit would you bring in first if you have a fogger and a plate. if you decide to run both kits.
thanks
studly
studly
Question for Steve Empty Re: Question for Steve
Post  Induction-Solutions November 8th 2010, 10:20 pm
From what I have learned two smaller kits will always be faster then one large one.. In this case I would leave on the plate as the smaller set up, then add the direct port system on top of it.. The plate won't hit as hard small, and the direct port will come on smoother then a plate with the larger hit in it as well.. Also, if you want to you have the option to bank the direct port system when you turn it on and soften it up a little more too.. Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
