Milodon 32227 Windage Tray?
Milodon 32227 Windage Tray? Empty Milodon 32227 Windage Tray?
Post  Mark Miller November 9th 2010, 1:25 am
Does anyone know if this will work with the Truck[Fox Body Swap Oil Pan]engine is 466 ci not a stroker if that makes any difference.
Thanks Mark.
Milodon 32227 Windage Tray? Empty Re: Milodon 32227 Windage Tray?
Post  rmcomprandy November 9th 2010, 12:12 pm
Mark Miller wrote:Does anyone know if this will work with the Truck[Fox Body Swap Oil Pan]engine is 466 ci not a stroker if that makes any difference.
Thanks Mark.
You should define WORK here. As in:
Does it fit...?
Will it stabilize oil pressure...?
What does it do for power...?
Post  Mark Miller November 10th 2010, 1:17 am
Thanks Mark.
Does it fit...?
All 3.
Thanks Mark.
Milodon 32227 Windage Tray? Empty tray
Post  Ed501 November 11th 2010, 12:46 am
One that i know works with that pan is the MPG one. It advertises a decent hp gain for trays. I have a canton tray and have never used the MPG but i am sure someone here has.
Ed501
Post  Mark Miller November 11th 2010, 1:12 am
Ed501 wrote:One that i know works with that pan is the MPG one. It advertises a decent hp gain for trays. I have a canton tray and have never used the MPG but i am sure someone here has.
Thanks i'll keep that in mind.
Later Mark.
