ok truck guys i need advice come on in heros need motor advice also
bb429power
frank13
found this thing locally,
http://philadelphia.craigslist.org/ctd/2040058172.html
what do i look for, any clue about the issue the owner talks about,,,,is this a good diesel to get?
Re: ok truck guys i need advice come on in heros need motor advice also
Rust rust rust rust rust, look everywhere for it. Under the carpet around the floor pans, ca mounts, tailgate, wheel wells, quarters, door jams. Look out for it, it is tricky to find a lot of times. Don't worry about being picky, if your buying it, you have every right to make sure what you're getting is a good deal.
The price seems low, maybe there is something else wrong? A lot f times the picture glorifies it, but you never know until you look at it. Go check it out, it could be one of those rare, really great deals you come across.
bb429power- Posts : 3129
What are you looking for Frank? My dad had one of those brand new and it was so gutless it could barely get out of it's own way. If you just need cheap transportation I guess it is worth the gamble that the fuel line is the "only" problem but for $580 bucks you can't expect a lot either. It really depends what your needs are but I would buy a gas job myself.
jasonf- BBF CONTRIBUTOR
im not really looking at all, but if its a good deal i will jump on something...may just pick it up fix it and flip it to make some cash....i would love a good truck to be a tow rig...,maybe get it and pop a stock 460 in her....
I personally wouldn't touch one with a ten foot pole again. I had one for here on the farm several years back, and gutless is a huge understatement, especially with the auto. The tires look completely bald, so there is about $600 missing, and as far as dropping a BBF in there, you will need a different trans and whole lot of work to get the fuel system switched. Just my .02.
schmitty- Posts : 4538
So in other words, stay away from the 6.9?
worked on a few, had to get out my history book to do it though.........
If you got it for cheap might be ok for a beater, not sure there is much money to be had in flippin' it............
ok so that one is off the list!
although now a days you can rebuild a whole IDI for about 50 bucks
That particular one would take some work and money to make something out of it. More than its worth, unless you really like those trucks and don't mind spending some cash on them. They are not powerful, and without a turbo they lack as schmitty said. But with a turbo they'll surprise you. THey're easy to work on, and easy to fix. The Return lines and glow plug controller in the early ones are the biggest problems.
the one i had rust was not a problem, even up north here as the thing always liked to leak something and it had a nice coat of oil underneath it.
My opinion is different then some, as i Loved my old IDI. mine was a 7.3 cw/ turbo, and an E4OD
Diggindeeper- Posts : 800
» this is for you ford truck guys
» Need some advice on a pro street truck build
» can i get your guys opinion on truck and price im looking at
» what are you guys using to keep your wheels looking shiny and nice ? any advice to clean with screwed rear rims ? methods ?
» mud truck guys
» mud truck guys
