Motor is IN!!!!!
+7
nuclearcobra
bb429power
11 posters
Motor is IN!!!!! Empty Motor is IN!!!!!
Post  BigBlockRanger November 14th 2010, 9:25 pm
Whoo hoo!
Motor is IN!!!!! 72250_460236589484_687514484_5356973_7799016_n
Sticking that big sucker in was really easier than it should be. Engine trans & headers all at once.
Waaay up on the air. Actually kind of scary. lol
Motor is IN!!!!! 149230_459792369484_687514484_5351246_2907871_n
nom nom nom
Motor is IN!!!!! 75668_459792434484_687514484_5351248_6998014_n
Motor is IN!!!!! Empty Re: Motor is IN!!!!!
Post  bb429power November 14th 2010, 9:51 pm
Shocked Somethings wrong, no engine slips in that easy. You sell your sole to the devil recently? Looking good Cool
bb429power
bb429power
Post  bruno November 14th 2010, 10:20 pm
where did the ranger go ???
http://WWW.CKRME.COM
Post  BigBlockRanger November 14th 2010, 10:47 pm
Ranger's carcass went bye bye via Craigslist a little less than a year ago, just after I bought this car.
I jacked the back end up as high as I could get it and it wiggled in. Took a little bit to get it in, but it was about the easiest swap I have ever done. Besides the steering shaft, the only things I had to remove were the brake lines right at the m/c and the valve covers.
Post  bruno November 14th 2010, 11:00 pm
very cool ...good luck with the build
Post  jbozzelle November 15th 2010, 12:04 am
What headers and k-member are you using?
Post  BigBlockRanger November 15th 2010, 12:44 am
Hooker headers and a QA-1 k member. I do have 1.5" spacers installed in it as well.
Steering shaft looks like it is going to be buckets of fun to reinstall.....
Post  res0rli9 November 15th 2010, 1:02 am
Looks good. Got a pic of the other side motor with headers on. They look like they mite fit my truck, mine hang to low.
Post  billandlori November 15th 2010, 5:40 am
BigBlockRanger wrote:Hooker headers and a QA-1 k member. I do have 1.5" spacers installed in it as well.
Looks right at home in there!! Nice job. Cool
The steering shaft is a b**ch. I ended up pushing the lower section of the column up into the upper so the U joint is right at the firewall. The I extended the steering shaft about 2-3" and still had to beat the crap out of a couple of tubes. It still rubs a bit.
PM if you want some pics....
Bill
Post  BigBlockRanger November 15th 2010, 10:42 am
I have already moved the u-joint back and extended the steering shaft. Getting to that top bolt may be a trick with the booster in there.
I bought these headers that were installed but never run, so they have already been dinged here and there for clearance. lol
Post  BigBlockRanger November 15th 2010, 11:29 am
res0rli9 wrote:Looks good. Got a pic of the other side motor with headers on. They look like they mite fit my truck, mine hang to low.
For some reason, I do not have a good side view of the other side.
Post  BigBlockRanger November 15th 2010, 5:27 pm
Checked hood clearance at lunch today. It is looking like I just might squeeze this under the factory hood and scoop. The bottom of the factory scoop will be 2" above the bottom edge of the ruler.
Motor is IN!!!!! 166xdet
From the top!
Motor is IN!!!!! 2wny1qt
Post  BigBlockRanger November 19th 2010, 11:17 am
Checking hood clearance with the air cleaner on. That is a 3" filter with a drop base and the lid just touches the bottom of the factory scoop. Might try to find a 2.5" tall filter just to be safe.
Motor is IN!!!!! 76507_462794219484_687514484_5388509_7845293_n
Sneaky.
Motor is IN!!!!! 155605_462794184484_687514484_5388508_987453_n
cheers
Post  billandlori November 19th 2010, 3:17 pm
Nice. Cool Very sneaky.
Did they have a stock forward facing scoop too? I thought Ford did and they could be made to be fuctional and get some cool are in.
Bill
Post  BigBlockRanger November 19th 2010, 3:49 pm
The '82 GT's had a forward scoop. Actually the back panel on this one is removable too.
Post  nuclearcobra November 19th 2010, 4:10 pm
Those headers are a pita but i didnt want to bash them or move the steering wheel so i changed the pita tube a little. Motor is IN!!!!! Th_BigBlockheaderfix004-1 Motor is IN!!!!! Th_BigBlockheaderfix005-1 Motor is IN!!!!! Th_BigBlockheaderfix008-1
nuclearcobra
nuclearcobra
Post  7litrestang November 19th 2010, 6:55 pm
Sneaky.
cheers
What's w/ the crapmaro wheels?
7litrestang
Post  BigBlockRanger November 19th 2010, 7:05 pm
lmao
They were free. And I had a set of 16" tires available.
The hot rod budget has been focused on getting this thing moving under it's own power. I will change the wheels later after the important stuff is done.
Post  res0rli9 November 19th 2010, 7:25 pm
BigBlockRanger wrote:lmao
no you wont! you like them Razz
Post  Lem Evans November 19th 2010, 7:36 pm
Nice.... Cool
Post  95lightiningguy November 20th 2010, 3:11 am
Hate to say it but those wheels are the only thing I ever liked about the lamaro. Shocked Cool That is great lookin car, I'm jealous.
95lightiningguy
95lightiningguy
Post  56Tbird November 20th 2010, 10:26 am
I'd be willing to bet that those "available" 16" tires won't be hangin around to long with that BBF sitting in the engine compartment lol! I love this build!! Super sleeper!! great job Twisted Evil Twisted Evil king
56Tbird
56Tbird
