swapping a 1988 10.25 sterling into my '95 truck- issues?
swapping a 1988 10.25 sterling into my '95 truck- issues? Empty swapping a 1988 10.25 sterling into my '95 truck- issues?
Post  Greg_P December 21st 2010, 11:41 am
Will this rearend out of an 88 F250 w/460 bolt under my '95 F350 w/powerstroke? It looks like it will. Is it as strong as the '95 model year axle?
Thanks,
greg
Greg_P
Greg_P
swapping a 1988 10.25 sterling into my '95 truck- issues? Empty Re: swapping a 1988 10.25 sterling into my '95 truck- issues?
Post  schmitty December 21st 2010, 5:14 pm
Should be a bolt in deal. I believe the Sterling axles were used from 83 or so on up to present. The only difference being the SD's used a drive flange instead of a U-joint yoke on the pinion, and I believe maybe a variant of pinions somewhere. I put a 97 model year Sterling in a 79 F350 several years ago, and it was a bolt in deal too. I had to modify the rear driveshaft a little and use a combo U-joint. Cool
Post  strokedmyford December 21st 2010, 8:24 pm
should be a bolt in deal as schmitty said, as long as one of them isn't a dual rear wheel.
strokedmyford
strokedmyford
Post  Diggindeeper December 21st 2010, 9:06 pm
93 and up use a longer pinion. overall its only about 1/4 or 3/8" difference.
Diggindeeper
Diggindeeper
Post  Greg_P December 22nd 2010, 1:22 pm
Thanks, guys!
Greg
Greg_P
Greg_P
Post  maxxoffroad January 2nd 2011, 11:17 pm
The 99 up are also a different bolt pattern went from 8x6.5 to 8x170. Also 99 up is 10.5 ring gear vs 10.25. Should be a direct bolt in with what you have
maxxoffroad
maxxoffroad
http://www.lonestaraxle.com
Post  schmitty January 3rd 2011, 12:01 am
maxxoffroad wrote:The 99 up are also a different bolt pattern went from 8x6.5 to 8x170. Also 99 up is 10.5 ring gear vs 10.25. Should be a direct bolt in with what you have
Completely forgot about Ford doing their own thing with the one off bolt pattern on the SD's. Evil or Very Mad
