Mud on the windshield!!!!!
+6
466bronco
digger460
bb429power
mudtrucker
10 posters
I dont get 10 feet into the pit and my windshield is completely covered and I have to drive looking out the door. Because of this I do not have any glass or lexan in the drivers door,because of that I get covered with mud and water every pass. I thought about going with a lexan windshield with a "gunners" slot cut in it or a lexan side window with a slot in it or maybe both. What are you guys doing?
mudtrucker- Posts : 160
Re: Mud on the windshield!!!!!
I know of a guy that turns his windshield wipers on before he hits the pit, maybe put some rain-x on it to boot. Sounds stupid but if your going through the runny type of mud it may work, if your going through the thick mud then I don't know. I'll find one of his video's.
bb429power- Posts : 3129
I just put wipers on my big truck with a rain-x type stuff and it beads the dirt and salt right off.
Not sure it would keep up with the amount of mud your putting on it though....
Bill
Bill
billandlori- Posts : 2081
You got TREED! Same answer too.
https://www.youtube.com/watch?v=1TIyvnBTsGM&feature=mfu_in_order&list=UL
https://www.youtube.com/watch?v=1d20PDMbcxI&feature=mfu_in_order&list=UL
bb429power wrote:You got TREED! Same answer too.
Yes indeed.....my reflexes aren't what they used to be!!
Bill
maybe windshield wipers along with carring a couple gallons of water and a 12v water pump to spray water on the windshield
digger460- Posts : 84
Fill the windsheild washer fluid resivour with water and hook a switch up so it will spray water during the whole run without having to hold the button.digger460 wrote:maybe windshield wipers along with carring a couple gallons of water and a 12v water pump to spray water on the windshield
If you run the really nasty stuff, do what the Louisana boys do and put a 4 wheeler sprayer with a pipe and nozzles on top and bottom of the windsheild, and run the wipers with some good blades on them.
Where you been Digger?
schmitty- Posts : 4538
My computer crashed and I lost all my web sites. When I got a new one I had forgotten about this site until I ran across it on the net somewhere. I blew up the motor in my pullin truck and Have gotten into a mud bogger. So I'm in the process of Doing a new motor for the pullin truck and trying to make this bogger right.
Glad to know you found us again. I lost your # a couple years ago, and wanted to come say hi when I ran up to Sturgis the last two years. You should get up to the Buffalo Chips and come run in the mud with us.
On our old horeshoe mud racing truck,we put a 25 gallon spray tank in the back of the truck.Put some nozzles above the windshield turn it on ,and the wipers athe the line.
466bronco- Posts : 23
The best solution I found for keeping mud off the windshield is to GO FASTER dont give it time to land on the windshield.
lghting94- Posts : 762
This is the best reply I have heard yet!!!!!!lghting94 wrote:The best solution I found for keeping mud off the windshield is to GO FASTER dont give it time to land on the windshield.
Going fast is a great way to keep the mud off, but if you can't, I've seen guys cut holes in the lexan windshield to be able to see. I have also seen them make shields to go over the holes to keep water from coming into the cam when you wash. Not my truck, but to give you an idea of what I'm talking about:
http://thepitatvms.com/gallery/?album=1&gallery=4&nggpage=2
kjett- Posts : 1169
schmitty wrote:If you run the really nasty stuff, do what the Louisana boys do and put a 4 wheeler sprayer with a pipe and nozzles on top and bottom of the windsheild, and run the wipers with some good blades on them.
This works great. We've used them for a couple years. If you keep an eye on Northern tool and tractor supply they will usually have a 12 gallon sprayer on sale for $89. The one I bought puts out 60psi. While everything is tore down this winter I will be putting my rad in the back, I plan on using a t-splitter and small ball valves so i can use the spray wand and extra hose on it to clean the radiator, windows, driver, etc.
wvmudder- Posts : 139
from a la. boy. windshield use only speedglass
rig a spray pump w/nozzels
ck. it out on speed tv.tomorrow at 2.30 cental time
home of big red racing.
glenn
glenn
glennm5413- Posts : 1
Glad to have you aboard Glenn. Welcome to the home of the Truck Mafia.
» Windshield
» Fox windshield trim
» Lexan windshield
» Stainless windshield trim 1973 ford truck 9" traction lock 2.75 ratio
» Lexan windshield
