? about nitrous usage on motot
? about nitrous usage on motot Empty ? about nitrous usage on motot
Post  Dre Day Fri 31 Dec 2010 - 23:01
If you have a 1000 horse power motor N/A that is built for nitrous also how do you determine how much nitrous spray and determine how many stages you need?
Dre Day
? about nitrous usage on motot Empty Re: ? about nitrous usage on motot
Post  studly Sat 1 Jan 2011 - 18:10
depends on what you are trying to accomplish. If you are running Pro Mod you are going to want several kits, If you are running a small tire car maybe just one kit. If you are asking how much you can spray on a 1000hp motor you just keep adding jets until it does not pick up or you kill it
studly
studly
Post  bruno Sat 1 Jan 2011 - 19:35
the class you are wanting to run i would do 2-3 kits 600-800hp worth of the juice should net you were you want to be with et and the weight ........ I would get with Steve from Induction-Solutions and tell him about your engine build and im sure he will get you in the right direction ... i believe your engine builder and nitrous guys should communicate on such an elaborate build
http://WWW.CKRME.COM
Post  Dre Day Sat 1 Jan 2011 - 19:40
Thanks bruno for the info did you get yourpm I sent you?
Dre Day
