need some vaccum help
f250mike
dirty intentions racing
need some vaccum help Empty need some vaccum help
Post  dirty intentions racing January 17th 2011, 9:20 pm
im pumped i found a site for just big blocks here's my problem i have a standard bore 71 block dove heads running a extreme 4x4 270 and bleed down lifters stealth intake and a 830 hp carb 2 inch madd dog fenderwell headers havent started it yet i have to pull 15' at 1000 rpms has enybody ever run this cam and any input on if it will pull vucuum or not
need some vaccum help Empty Re: need some vaccum help
Post  f250mike January 17th 2011, 10:41 pm
I use to run the 15" vacuum class. I'm no cam expert but have been around the block a couple times Wink .
In my opinion that cam will be real close if everything else is right. Too many variables to know for sure.
The lobe separation of that cam is 111*. That's going to hurt your vacuum some.
The duration and lift is close to what I ran but mine had a 114* lobe separation.
Compression will also be a factor. Mine has +.060 bore flat tops with a 0" deck block.
good luck
mike
f250mike
f250mike
Post  schmitty January 17th 2011, 11:34 pm
A whole lot of variables, but you should be close. Cool
Post  lghting94 January 18th 2011, 9:58 am
To help with vacuum you need to build as much compression as you can, and run as small a carb as you can and still feed the engine, then run the carb lean on idle to help a little also. Just a few tricks I have learned over the years.
lghting94
lghting94
Post  dirty intentions racing January 18th 2011, 12:17 pm
cool thanks u guys im sure ill have more questions first time building a mud truck with rules to follow
Post  tiger January 19th 2011, 1:16 pm
You can always advance the cam some and it will increase the vacuum and the power band will be at a lower rpm.
tiger
Post  BRONCOBILLY7.5 January 19th 2011, 4:05 pm
Dirty, I ran that same cam in my 466 before switching to a solid flat. Pretty much same specs as yours. .030 over D1 block, Dove heads, appr. 12-1 comp., 8012 Stealth BUT with a 750hp carb and L&L 1.750 headers. Pulled a steady 14-15in vacuum @ 1000 rpms. Billy
BRONCOBILLY7.5
BRONCOBILLY7.5
Post  strokedmyford January 19th 2011, 10:11 pm
Locking the timing @ full advance helps also.
strokedmyford
strokedmyford
