What size fuel pump
What size fuel pump  Empty What size fuel pump
Post  Big block fox 339 January 27th 2011, 12:23 pm
545
10.8-1
Dove heads
C460 cam
Victor intake
QFT 950 E85 carb
1/2 " alum line
Full weight fox on 275's
3.73 gears
It's got a Holley 110 gph mechanical pump on it now
I'm wanting to put a 150 shot on it
What size elec pump do I need for engine and nitrous ?
Thanks Micah
Big block fox 339
Big block fox 339
What size fuel pump  Empty Re: What size fuel pump
Post  Barney January 27th 2011, 1:45 pm
1 Mallory Comp 250 should be plenty, and give you room to grow down the road.
Barney
Barney
Post  richter69 January 27th 2011, 2:22 pm
Barney wrote:1 Mallory Comp 250 should be plenty, and give you room to grow down the road.
X2, best electric pumps I've ever owned...........
Post  Big block fox 339 January 27th 2011, 2:44 pm
Do you have to run a return line?
Big block fox 339
Big block fox 339
Post  P.Lafferty January 27th 2011, 7:53 pm
The comp 250 pump has a return coming off the pump you can run back to the tank.
P.Lafferty
Post  richter69 January 27th 2011, 11:10 pm
The return on the pump is for use with a deadhead style regulator, I used a Mallory 5 port with mine, might be why it lasted so well. With the return style reg you cap the bypass on the pump.
Post  BOSS 429 January 28th 2011, 12:38 am
the min size i run is a 140 mallory, and we have used 300 shot with (140) these, no returned needed.
the 250 pump is one of the best, and if mounted in the rear the returned can be ran right back to the top of the tank/cell,and a dead head reg used in the front,works perfect
-rich
