4 digit horsepower possible with dove heads?
quick 52
Barney
Bigblockfox
4 digit horsepower possible with dove heads? Empty 4 digit horsepower possible with dove heads?
Post  Bigblockfox February 4th 2011, 11:11 am
I am getting a new 460 from a buddy. It has about 35 passes on it and then he sprayed it and it hurt 2 pistons. Im going to put 2 new pistons and a set of rods in it. With a set of ported dove heads and a vic or torker intake with a bigshot kit is it possible to make 1000hp with it? Will dove heads flow that much?
Bigblockfox
4 digit horsepower possible with dove heads? Empty Re: 4 digit horsepower possible with dove heads?
Post  dfree383 February 4th 2011, 11:21 am
You may just hit a wall (Not enough port)with the heads, unless they are "Pro Ported and heavily modified"
Plus thats a big number if the block is stock and depending on what parts your using it might be a grenade...??
Post  Bigblockfox February 4th 2011, 12:10 pm
Stock block and crank. Im just thinking out loud. Its boring around here with all the snow on the ground. This motor is a flat top motor and Im putting in my 85 to play around on the street.
Bigblockfox
Post  dfree383 February 4th 2011, 12:54 pm
Block will be walking around, Crank should handle it, Decent Hbeam and NO2 designed Forged piston should work.
A decent build 466 @ 12:1 with a big roller cam, Victor and 1050, decently ported DOVE heads with big valves will lay down 650-675 hp+/- NA.
Thinking out loud myself, I dont think you'll have enough exhaust port to support 1000hp with a 400 ish shot on the motor.
Post  Bigblockfox February 4th 2011, 2:09 pm
My 466 thats in my car now has 2443 pistons, ported doves with bigger valves, .292(iirc) .631 solid roller, stock rods and crank through a c6 with a ati 3500 converter and 9in rear. It makes 442 to the tire.
Bigblockfox
Post  dfree383 February 4th 2011, 2:20 pm
Forget it with the Stock Rods...... Your motors making 550ish hp now and they are decently safe at that range, you try hitting that motor with a 500 shot (if it will digest it) your gonna be oiling down the track and building a new motor. May get away with a 100-150 shot with a safe tune.
Post  Bigblockfox February 4th 2011, 2:23 pm
dfree383 wrote:Forget it with the Stock Rods...... Your motors making 550ish hp now and they are decently safe at that range, you try hitting that motor with a 500 shot (if it will digest it) your gonna be oiling down the track and building a new motor. May get away with a 100-150 shot with a safe tune.
Not going to spray this motor. Its going into a different chassis when I get it finished. The 460 with the melted pistons is what im going to spray. I will put my eddy rpm kit or my bigshot kit on it. Its just a street car.lol
Bigblockfox
Post  Barney February 4th 2011, 3:27 pm
At 3085# and 151 in the 1/4 my stock cast piston, truck rod shortblock was making around 830 to the wheels. That motor was a D9 block, stock everything w/ D0VE heads that were Max ported. Big shot plate 110N jet. It never hurt anything, in fact I sold that motor this fall and its still kickin. It can be done. Whether or not it should is another question.
Barney
Barney
Post  Bigblockfox February 4th 2011, 3:47 pm
Barney wrote:At 3085# and 151 in the 1/4 my stock cast piston, truck rod shortblock was making around 830 to the wheels. That motor was a D9 block, stock everything w/ D0VE heads that were Max ported. Big shot plate 110N jet. It never hurt anything, in fact I sold that motor this fall and its still kickin. It can be done. Whether or not it should is another question.
Who worked the heads?
Bigblockfox
Post  quick 52 February 4th 2011, 3:57 pm
and i worry with 100hp hit but i have a weak overdrive trans its held so far even locking the converter on spray
quick 52
Post  Barney February 4th 2011, 4:11 pm
I did the shaping of the ports, and Circle R did the welding and finish work.
Barney
Barney
Post  BOSS 429 February 5th 2011, 2:30 pm
yes these were D0VE heads,this engine ran very well
Post  kjett February 27th 2011, 10:18 pm
I know a certain D0VE headed 466 with forged flat tops that sees an occasional 250 shot and works fine Wink
kjett
kjett
Post  BOSS 429 February 28th 2011, 11:13 am
i wouldnt try it with stock rods,unless it was a ger(boom) nad engine that i didnt care about. but then thats a lot of wasted time and money
Post  kjett February 28th 2011, 12:51 pm
Doh! I missed the stock rod part. Mine is h-beam rods.
kjett
kjett
Post  ThndrChkn April 1st 2011, 12:48 pm
I agree, it can be done. But like was stated above, "everything has to be right". I did a 466 on a D9 block, with stock rods, coated hypers, and stage II ported D3's, a 8012 Stealth intake and an 850 Holley. In my '86 F150 super cab, @ 5600 lbs., it would run 108 mph in the 1/8 on a 200 shot.
ThndrChkn
ThndrChkn
Post  valleydawg April 1st 2011, 1:23 pm
Man I have sprayed my share of nitrous but I believe I would be real concerned if I was going to spray 400+ on stock rods and crank and then turn it like you would need to if you want to see 1000. I was probably making that number with a stock block but I have an aftermarket crank and rods and had a girdle on the block. I also had two systems. Let me know how this turns out.
valleydawg
valleydawg
Post  crittersf1 August 24th 2011, 8:11 pm
The big end of the rods are really going to hate you
crittersf1
crittersf1
Post  BOSS 429 January 29th 2012, 11:35 pm
HOW DID THIS GO FOR YOU?
