OLD BLUE BEFORE AND AFTER
OLD BLUE BEFORE AND AFTER Empty OLD BLUE BEFORE AND AFTER
Post  69F100 July 9th 2009, 7:51 pm
Here are some pic of old blue the 1st of last year 08 did everything myself
OLD BLUE BEFORE AND AFTER DCAM0018
OLD BLUE BEFORE AND AFTER DCAM0015
OLD BLUE BEFORE AND AFTER DCAM0003
OLD BLUE BEFORE AND AFTER DCAM0002
OLD BLUE BEFORE AND AFTER IM000520
OLD BLUE BEFORE AND AFTER IM000519-1
OLD BLUE BEFORE AND AFTER IM000549
OLD BLUE BEFORE AND AFTER IM000552
OLD BLUE BEFORE AND AFTER IM000541
OLD BLUE BEFORE AND AFTER IM000538
OLD BLUE BEFORE AND AFTER Empty Re: OLD BLUE BEFORE AND AFTER
Post  Old blue Racin Team July 9th 2009, 8:09 pm
Looks Good Man
Old blue Racin Team
Old blue Racin Team
Post  69F100 July 9th 2009, 8:21 pm
Thanks the first time i painted it did not come out worth a flip the paint i order must to have been bad just wouldn't lay down right and they said send it back asked how was i supposed to do that when it was on the truck i mix everything up before i started spraying with the harder and tinner i want be buying anymore from trinty paints.
Post  Northwest outlaw July 10th 2009, 10:31 am
looks good
Northwest outlaw
Northwest outlaw
Post  69F100 July 18th 2009, 8:07 pm
here is couple more pics and vids
OLD BLUE BEFORE AND AFTER 69F100003
OLD BLUE BEFORE AND AFTER 69F100002
OLD BLUE BEFORE AND AFTER Th_69F100001
OLD BLUE BEFORE AND AFTER Th_69F100005
Post  Old blue Racin Team August 5th 2009, 3:37 pm
Damn looks pretty Good man
Old blue Racin Team
Old blue Racin Team
Post  73f100shortbox557SCJ August 9th 2009, 12:07 am
tell us a bit about the motor ?
nice pickup im fond of the 2 wd shortbeds as well!
Post  69F100 August 9th 2009, 5:27 pm
Well I have had it for about 15 years got it from my dad it came with a 300 6cyl. auto trans, power steerig, and a/c under dash from the factory, when I got the truck it had a 77 302,fmx trans out of a tbird built a 70 351cid 4v motor out of a 70 mustang that was totaled out it had around 525 hp c6 trans 3000 stall,410 gear got 5 miles a gallon but gas was cheaper then put around about,30000 on it before it droped a valve took the block ,one rod out sold everything and put 72 351w and fmx trans back in it and about 3 years ago rebuilt the the engine it has 70 model reworked heads stock except springs ,cam 292 512 lift, pistons stock 30 over for 69 4bbl engine,intake offy 360 duel plain,625 holley carb.Took the truck mostly apart reworked the insides had to do some floor board work where the rubber mat had a hole and caused some rust but the truck is mostly rust free alittle on the bottom rear corners of the doors only cut that out and weld some patches in now all the rust is fixed except some in the bed where the tool box was on it but got to get the line-x bed liner out 1st that will be a pain it will not stop rust that a story for another time.So right now I need seat reworked,under the hood,the inside of bed,and a set of wheels after i finish the ranger.
Post  RapidRuss August 10th 2009, 8:37 am
Very Cool...Love the Color....Its about the same shade of blue as my 70 F250, But mines a LB.. I bought mine back in 74, and has been with me ever since! I love that Ol Truck...Hence mines named Ol Blue...Originally Ford Harbor Blue... Very Happy
RapidRuss
RapidRuss
Post  69F100 August 10th 2009, 9:09 pm
It is #2510 Daytona Blue Metallic from here http://www.tcpglobal.com/restorationshop/ that is the color i painted my 460 I will see how it holds up on a engine the inside is gun metal gray, it was red with white top org. but when I got it it had been repainted with laytex house paint with a brush and was peeling worse than a old house you could be going down the road and it would blow off no joke I got some picks somewhere i will scan and post when I find them again you talk about a hillbilly looking truck
Post  Old blue Racin Team August 11th 2009, 11:02 am
THat is a cool color
Old blue Racin Team
Old blue Racin Team
Post  69F100 August 11th 2009, 4:57 pm
looks like I am going to have to repaint the dash it is turning loose you can see in the pics under the ash tray
