nitros plate and meth
nitros plate and meth  Empty nitros plate and meth
Post  cobra501 February 15th 2011, 12:54 pm
Im going to run a 200 shot of gas and also a water/meth kit but dont have alot of hood clearance , is there any alternatives? IDEAS?
cobra501
cobra501
nitros plate and meth  Empty Re: nitros plate and meth
Post  whatbumper February 15th 2011, 1:48 pm
how does the water/meth kit benefit a nitrous motor?
Post  cobra501 February 15th 2011, 3:32 pm
Car running on pump gas however my CR is about 10.2 so I should be ok without water/meth however I just want to experiment a little. Im sure it wont hurt though. The fine mist of water and alcohol (methenal) can make up to or more than 100 hp on engines running forced induction without a cooler. Its gotta bennefit on N/A engines like mine I would think. I have a friend also leaning this route with a 12.5 cr and 750 hp at the wheels. Snow performace says he can run pump gas with the right mix and good tune. This equals to more play time without breaking the bank. I dont personaly have any experience with this so if you do please educate me so I can help others. thanks I also plan on installing a small fuel cell for race gas to control detonation when on spray.
cobra501
cobra501
Post  whatbumper February 15th 2011, 11:56 pm
well, if you've never used either I would recommend running one and figuring it out before throwing two variables in the mix. I've sprayed lots of motors but have never ran water/meth so I can't say it is good or bad.
Post  richter69 February 16th 2011, 11:43 am
whats wrong with running a better race gas on the spray?
Post  cobra501 February 16th 2011, 1:59 pm
I plan on running better gas on spray. The water is not for the nitros at all. Its for controlling detonation while using pump gas on cruise night. The problem will be stacking plates. 1 inch for NOS plate abd 1 inch for water/meth plate equals 2 inches. I just dont think all thats going to fit under hood. Question is has anyone had this problem and how did they solve it. Maybe a plate serving both nos and meth? Is there such an animal.
cobra501
cobra501
Post  richter69 February 16th 2011, 2:01 pm
drill manifold and put water/meth spraybar in intake plenum.
Post  cobra501 February 16th 2011, 3:41 pm
thats probably the only solution till i get it in my hand and then way my options.
cobra501
cobra501
Post  whatbumper February 17th 2011, 11:32 pm
Shouldn't get detonation with a 10.2:1 motor on pump gas.
