kingpin dana 60..... what wears out on the steering knuckles
Im replacing the gears in the front of my F350. I have had some kind of on center binding in the steering for a couple of years. Finally replaced all the steering parts except the kingpins themselves.
So.
What wears out up there?
Greg
So.
Greg
Greg_P- Posts : 1009
Re: kingpin dana 60..... what wears out on the steering knuckles
Usually they get dry on grease and freeze up or wear on themselves.
56Tbird- BBF CONTRIBUTOR
I popped the upper and lower plates off the driver's side, and it was full of grease. But it looks like the upper joint is a plastic ball?
The lower joint I ca't get to I guess without taking the upper pin out.....which I'm not sure how to do....
Greg
Greg
D-60
On those king pins that is a plastic sleeve, and there should be a spring in there too, once it wears out it will be metal on metal. The bottom has a bearing if I remember correctly its been about 10 years since I rebuild one. The cone can also be changed out it uses a large allen socket, I'll try to find a pic.
Okay found a link and a schematic for you with instructions ! LOL Go for it.
http://www.pirate4x4.com/tech/billavista/PR-Kingpin/index.html
FWIW Mark
FWIW Mark
Last edited by Mark Laczo on February 25th 2011, 9:34 pm; edited 1 time in total (Reason for editing : Added Link)
Mark Laczo- Posts : 274
» anyone run a rack and pinion steering on a dana 44 straight axle???
» dana 44
» dana 44
» DANA 609
» Dana 60
» dana 44
» dana 44
» DANA 609
» Dana 60
