7531 msd launch and gear retards
Anybody on here have experiance with a 7531 on N20 with no progressive allowed?
Are you willing to share?
studly- Posts : 512
Re: 7531 msd launch and gear retards
i do not have any experance with it.a friend that is useing the 7531 told me that you put what ever pills in you are going to use.then retard the timeing back to were it will 60ft then you ramp the timeing back up.
he also has the progressive controler i asked him how is that going to work in the classed were your not suppose to have it?he said ill just unhook the ground i would like to be around to see how that fly's around here if it says no controler it had better not be in the car.
Larry T- Posts : 1076
Here's a link on it that has some vidio's, and there is also a link to MSD info page.
http://www.dragzine.com/tech-stories/ignition-tech/msds-pro-data-software-7531-tech-videos/
racnrick- Posts : 462
Are you going with launch or gear retard ??
They both can work and some look at each with pro's and con's..
Launch retard pulls the timing when you set the trans break (which some with tight converters can have an issue getting RPM up when timing is out) and then ramps timing back in timed based.
Using a gear retard is all RPM based. I like this for the most part, but somewhat can bite you. If you start to spin the tire, and the RPM increases (even faster now) it runs the timing in as well and can compound the problem.. Hope this helps.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
I was trying to use both, i am using launch for the intitial hit than using the gear to keep the tires from spinning in the gear change
studly- Posts : 512
studly wrote:I was trying to use both, i am using launch for the intitial hit than using the gear to keep the tires from spinning in the gear change
stick with the gear retard. if you have questions pm me.
whatbumper- Posts : 3024
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
» MSD 7531 NEW IN BOX
