Another Magazine Build
+8
steve1071
FORDMUD
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
http://www.mustangandfords.com/techarticles/engine/mdmp_1102_385_series_ford_big_block_build_part_3/index.html
Anyone seen this one yet? Seems lacking but no slouch. Obviously, could've used A-heads and been much cheaper with very similar results.
windsor- Posts : 1167
Re: Another Magazine Build
The Problem is the out of box heads, a good port job and the proper camshaft and that engine will wake-up. Need's TI Valves too..........
Do you have to work hard to get flow numbers that weak?lol
FORDMUD- Posts : 290
One can pick away at will at all of the stuff that could have been done, small carb, no porting, Ti valves, etc., but 915hp and over 800tq is not too shabby for what it is. Sure wouldn't take much to make it better though, and it would have only been a couple grand more $$$$.
schmitty- Posts : 4538
Putting it into perspective it 1.53 hp per CID, nothing spectacular and below average considering the parts.
good compairison is Sherrys 598 with A460 heads.......@ 1.75 hp per CID more inline with what I'd have expected for mildy preped C460's and a single 4.
Also shows how good the wet flow is on a set of C460's......... 2.41 hp per CFM......
But like your saying schmitty, its easy to critisize.....
Who actually designed the C heads for Ford, and what were they originally designed for?
Ford took the Yates SBF heads and Sized'em up to fit on a BBF.
magazine engine
I would have liked to see this build done with out of box a-head ,and less fu fu shit (plug wire separators ,painted alum heads WTF ) and a real cam !
steve1071- Posts : 91
This engine was FAR from tuned with a small camshaft and only a few pulls to help it.
With "out of the box" unported heads this engine is about right where it should be. The Kasse ported heads they speak of in the article would add another 100 horsepower at least.
Edit: 380 CFM intake flow @.700" valve lift is how those heads are delivered and shows nothing about their capabilities.
steve1071 wrote:I would have liked to see this build done with out of box a-head ,and less fu fu shit (plug wire separators ,painted alum heads WTF ) and a real cam !
Why don't you build one of your own with "out of the box" A460 heads...? Then you can build it however you want with none of the "fu fu shit".
Oh, that's right, you simply wish to criticize other people's choices and make derogatory, suggestive comments or hang on the coat-tails of other people's testing without spending any of your own dollars.
Prove me wrong ... I'll be very interested to see the testing results you put forth here.
I did build a motor with out of the box Ahead at 11.7 comp 557 motor , I was just curious what the extra cubes and the free comp ratio would do to power out put . I would rather have seen some thing done that would be of some use but thats not normally what happens with these mag builds ,although there have been some good ones . (when was the last time someone used unported c-heads for a budget build ?)
As touchy as you are about me critisizing a magazine build makes me wonder if you like building a high budget big cube under powered excuse for a ford motor !
steve1071 wrote:As touchy as you are about me critisizing a magazine build makes me wonder if you like building a high budget big cube under powered excuse for a ford motor !
It was of use ... to them.
They didn't build it to suit your priorities or expectations; just theirs.
I am simply saying that if you want to satisfy YOUR priorities then you should do it. Don't expect somebody else to satisfy what you want.
Well i'm glad they ddin't build it to impress me either..................because it ddin't lol.
The facts are that Ford ask [paid] Robert Yates to scale his SBF heads to a BBF head...which he did.dfree383 wrote:Ford took the Yates SBF heads and Sized'em up to fit on a BBF.
besides with all the internet now how out there who reads magazines anyway?????
last one I read didnt have any car stuff in it anyway..............
richter69 wrote:besides with all the internet now how out there who reads magazines anyway?????
HeRo's only need Pictures........
Your serious i thought you guys were kidding about scaleing up the yates to a BBF head, they are nasty those yates headed small blocks are probley the fastest small fords i've seen yet.Lem Evans wrote:The facts are that Ford ask [paid] Robert Yates to scale his SBF heads to a BBF head...which he did.dfree383 wrote:Ford took the Yates SBF heads and Sized'em up to fit on a BBF.
nuclearcobra- BBF CONTRIBUTOR
I was reading a magazine article the other day and the car featured obviously had C heads, but they didn't call them that, they called them Yates heads. Makes sense now, thanks for the info.
Beast- Posts : 66
I thought the C heads flowed more then that out of the box? Out of the box P51s are in the 390s---all though the potential of the C head is significantly more. I was just surprised by the stock flow number listed for the C head.
C-heads
Someone with more experience correct me if I am wrong, but I don't think C-heads were really meant to be ran out of the box. They obviously have a lot of room in them to get much, much more out of them. Each custom engine builder/head porter can work their own "magic"(hand port or C&C) on them for a specific purpose. Such as dragrace N/A or nitrous, truck puller, gas, Alky or what have you. Nothing like an A-head deal. Who ever pays the bill may run them however they wish.
JMO Mark
JMO Mark
Mark Laczo- Posts : 274
psfracer wrote:I thought the C heads flowed more then that out of the box? Out of the box P51s are in the 390s---all though the potential of the C head is significantly more. I was just surprised by the stock flow number listed for the C head.
how did the car run man?
Page 1 of 2 • 1, 2
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
» Just got the new Hot Rod magazine and I am pissed
Page 1 of 2
