SHAFT MOUNTED ROCKER ARMS
+22
steven gregoire
powerstrokeace
DanH
BigDave65
CDMBill
Wheelie58
95lightiningguy
138
26 posters
Page 1 of 4 1, 2, 3, 4  Next
SHAFT MOUNTED ROCKER ARMS Empty SHAFT MOUNTED ROCKER ARMS
Post  c.evans June 26th 2011, 4:08 pm
Shaft mounted rockers.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES111
The picture above is of W.W. rockers on a Pro-Filer 205 head. This is showing the correct geometry pattern with the valve closed and the roller to the inside a little bit.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES82
The above picture shows the bottom side up of a Pro-Filer 205 one piece stand which is flat and in the background the bottom side of the new one piece stand for the TFS A-460 BBF3X head. Notice how the cant angle has to be incoorporated into the stand. So the one piece stand is for the intakes only. The exhaust stands are 4 individual stands that butt up against the long intake stand.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES88
This is a bottom side view of the Pro-Filer 205 in the foreground, and then the bottom side view of the new W.W. A-460 rockers in the background. You can see where the 4 exhaust stands are relieved to clear the head studs (shiny area).
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES56
W.W. Engineering A-460 rocker arms. They are 3D profiled, shot peened, and the nose lightened to reduce the polar moment of inertia.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES85
Just another view of the bottom side of the stands. The C-460, Pro-Filer 205, and Thor heads will all be flat across the bottom, because they are designed for shaft mounted rockers only from the get-go. In the background are the A-460 stands. The big improvement is that we have gotten away from 16 individual stands, which is something that Lem and several of us have been requesting for a long time. With the A-460 stands we have a compound cant angle situation, because the heads of course are designed to use stud mounted rocker arms and a stud girdle. So shaft mounted rocker arms are not for everybody, but if you need them, then I feel we have made an upgrade in the design here with the new W.W. stuff. Notice the lettering on the stands. With the W.W. pieces, the lettering will always face towards the exhaust port side of the head.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES84
This is a top side view of the stands. The new A-460 stand is in the background.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES64
The new TFS A-460, 18 bolt, BBF3X version of the heads, with the squared up rocker stud bosses. We can thank TFS for sending a head down to Wilfred for him to work on this project, which has taken a few months.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES52
Great view here. Those are 12 pt. ARP bolts holding the stands down. To improve the holding force of the exhaust stud, TFS has increased to depth of the threaded hole to like 1.250", so Lem came over and determined that the exhaust bolt could be a total of 1.500" long and we would still get full thread engagement. I will try to get Wilfred to include longer exhaust bolts (ARP 12 pt.) in the future. You can also see the "X" on the new head casting.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES44
Here you see the 3X on the new TFS casting and you can see the elongated pushrod slots, which is something we have had in the 18 bolt casting since 2005 I think.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES91
This is the Pro-Filer stand and it is important that all engine builders notice this. On heads that have CNC machined rocker bolt holes, such as the C-460, the Pro-Filer, and others,,,, it is important that you bottom tap all bolt holes. (The TFS A-460 heads have rolled threads, which are stronger.) Notice the 2 bolts under the intake rocker. The right hand bolt won't go all the way down, because it needs to be bottom tapped.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES45
This view shows how the exhaust stands butt up against the one piece intake bar/stand. AFTER all of your fitting, shimming and mock up, you could tig weld the exhaust stands to the intake stand. OR the right hand rocker arm hold down bolt, could be tapped into the square pad, with a much longer 5/16" bolt going all the way through and into the head. Of course you would have to etch mark the stand and always put it back in the same spot.
SHAFT MOUNTED ROCKER ARMS HEADSINTAKES48
Good view showing the slotted pushrod holes. We increased the body length of the rocker arm, and when you do that, your pushrod holes must move up towards the intake manifold. I'm always having to slot the pushrod holes in EX 514 head for example for the truck pullers that run then with shaft mounted rocker arms and turn 8500-9000 rpm.
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
SHAFT MOUNTED ROCKER ARMS Empty Re: SHAFT MOUNTED ROCKER ARMS
Post  Lem Evans June 26th 2011, 4:18 pm
Can the Torx + bolts as seen on the 205 heads be used on the A460 heads?
Post  cool40 June 26th 2011, 5:20 pm
nice looken rockers Charlie! Very Happy
Post  138 June 26th 2011, 10:25 pm
Basketball
138
Post  95lightiningguy June 26th 2011, 10:51 pm
Looks great but not sure them springs are up to the task. scratch Razz
95lightiningguy
95lightiningguy
Post  schmitty June 26th 2011, 11:03 pm
95lightiningguy wrote:Looks great but not sure them springs are up to the task. scratch Razz
I was thinking the same thing. Suspect Laughing
Post  cool40 June 27th 2011, 12:17 am
he must be planning on a hyd flat deal.those springs should'nt hurt it. Laughing
Post  Wheelie58 June 27th 2011, 7:26 am
Nice detailed pics. Most guys wont even take a picture of their shafts, much less post them on the internet! Shocked
Wheelie58
Wheelie58
Post  c.evans June 27th 2011, 9:17 am
Thanks Keith,
Up until now I have never posted a picture of anything on the internet, because I am a "dummy". Rolling Eyes It took a lot of work on Livermore Dave's part, along with big help from Lem to get those pictures posted. Thanks Dave & Lem.
I have a nice digital camera that I have learned how to use, and have got hundreds of pictures of heads and manifolds that I would like to post, because I believe it would be educational for the guys. Maybe I can do better in the future. Very Happy
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dfree383 June 27th 2011, 10:05 am
cool40 wrote:he must be planning on a hyd flat deal.those springs should'nt hurt it. Laughing
Those are the New Lemalloy-69 valve springs....... Laughing
Awsome Post Charlie. If you need help opening a photo bucket account give me a ring.
Post  Lem Evans June 27th 2011, 10:23 am
Wheelie58 wrote:Nice detailed pics. Most guys wont even take a picture of their shafts, much less post them on the internet! Shocked
Now you know where you can get the shaft affraid affraid
Post  Scott Foxwell June 27th 2011, 10:44 am
Great pics and good write up. I've never been a fan of individual stand shaft systems. IMO they don't have any where near the support/stability as a good stug/girdle set up. This is a great improvement for the A460 head. Will these work on an early set?
I sure like TF's castings...make Profilers look like high school shop projects. Rolling Eyes
Post  schmitty June 27th 2011, 1:09 pm
What are the spec's on those compared to the Lemmungus 96 spring? Laughing
Post  Paul Kane June 27th 2011, 1:19 pm
Thank you, Charlie. Cool
-P
Post  cletus66 June 27th 2011, 1:51 pm
Excellent pictures. Keep 'em coming. Cool
Post  138 June 27th 2011, 4:47 pm
Scott Foxwell wrote:Great pics and good write up. I've never been a fan of individual stand shaft systems. IMO they don't have any where near the support/stability as a good stug/girdle set up. This is a great improvement for the A460 head. Will these work on an early set?
really?
138
Post  cool40 June 27th 2011, 9:00 pm
i took a few of the WW's Charlie got for me,same thing he's got in the pic's but on eliminator head.Charlie had these made to be a "bolt on"for TFS 18 bolt heads so i thought i'd run into problems. Rolling Eyes but i only had to take a little off at the intake runner.a few minutes of work and they're on! these are some quality rockers!SHAFT MOUNTED ROCKER ARMS Rocker10SHAFT MOUNTED ROCKER ARMS Larry_10
SHAFT MOUNTED ROCKER ARMS Empty Clearance for stud and nut under shaft mount
Post  CDMBill June 28th 2011, 6:12 pm
On my older A-460 castings we had to grind the top of the stud and the 12 point nut to fit under the Jessel shaft mounts. Is that potentially the case with the WW's?
CDMBill
Post  Lem Evans June 28th 2011, 6:15 pm
CDMBill wrote:On my older A-460 castings we had to grind the top of the stud and the 12 point nut to fit under the Jessel shaft mounts. Is that potentially the case with the WW's?
The studs are longer than they need to be.........so the potential is there.
Post  cool40 June 28th 2011, 10:03 pm
what about bolts? can you even get a bolt in an A460 head? Question
Post  Lem Evans June 28th 2011, 10:16 pm
Sure one could........depends on the design.
Post  cool40 June 28th 2011, 11:13 pm
Lem Evans wrote:Sure one could........depends on the design.
i've heard some say they dont like studs,so.............
Post  Lem Evans June 28th 2011, 11:17 pm
So....what is the question?
Who is they?
A good well designed bolt would be great in my book.
Post  cool40 June 28th 2011, 11:30 pm
Lem Evans wrote:So....what is the question?
Who is they?
arp or anybody make one? hell i'd use a bolt before i give damn near 300$ for studs and then go to cut'n on them.lol
Post  c.evans June 29th 2011, 1:28 am
Guys here's the deal. On just about all A-460, B-460, C-460, Pro-Filers, E-460 heads and so on,,, when you are running head studs, you need to double check the clearance between the stud and the underside of your shaft mounted rockers stands. For years we've had to shorten those inner head studs and/or thin the 12 pt. nuts. True story,,,, just recently Phillip Oakley got a C-460 headed engine in here to rebuild, and some "expert engine builder" left the inner row of head studs standing way too tall, and then had bolted down the W.W. Engineering rocker stands and sent the engine out the door that way. In the process he ruined the rocker stands and some rocker arms. The bottom of the stands was bent like a horseshoe, because the end was resting on the long head stud.
Furthermore, as mentioned in the Ford Racing directions for the C-460 heads, Ford suggests that you use the B&B step shouldered washers to help prevent the bolt boss from pinching down/inward with the 140 ft.lbs. of torque that you put on the 9/16" studs. So we counterbore all the bolt bosses about .125" deeper in order to install the step shouldered washers. Stefs/B&B make a tool for doing this machining operation.
To compound the problem even more, ever since ARP has added the "internal wrenching" feature to their head studs, they have made them even longer than the old specs, and now you have to cut off a bunch of threads.
So the bottom line is that the engine builder should be smart enough to always check for clearance between the rocker stands and head studs, including washers and nuts. Another area to check for clearance is between the stands and the valve springs and retainers.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
