Dry Sump System
+12
strokedmyford
Wheelie58
badcoupe
DanH
JR Performance Motorsport
16 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Dry Sump System
Aviaid external single stage pump, integrated regulator in the filter housing. Junk ass Charlie's oil pan...................going on the 5th season on the same rod and main bearings...............no oil press drop even with the chute pulled at 160 mph.................not shown is the 3 qt accumulator........
The pump, filter, drive assy, hoses etc was somewhere in the 1000 dollar range give or take...........pan and accumulator not included
Re: Dry Sump System
I just don't know how you are doing it with such a Junk Pan, I just can't figure that one out ................hhhhhhhmmmmmm
the Coug- Posts : 3055
Re: Dry Sump System
rmcomprandy wrote:I would bet that those inline filters before the pump are screen.
Randy, you would win that bet!
Re: Dry Sump System
Nice looking stuff you have there!
What kind of block heater element are you using in that center core plug?
Thanks,
Keith
Re: Dry Sump System
here is where I got the block heaters
http://www.jerrybickel.com/cooling-systems/radiator-hose-heater-jbrc5527.html
Re: Dry Sump System
I see a small tube in the pan to pick up the oil? Is that the only way to pick the oil up? Buddy of mine has a swivel pick up is that not needed or the one ricker has just as good. I'm sure there are many ways to do it easier the better. One in front and in back
badcoupe- Posts : 112
Re: Dry Sump System
Can u also get an oil pump that also works as a vaccum pump to eliminate the need for both?
Re: Dry Sump System
Thanks dude!richter69 wrote:here is where I got the block heaters
Keith
Re: Dry Sump System
badcoupe wrote:Can u also get an oil pump that also works as a vaccum pump to eliminate the need for both?
Yes, Peterson makes one but I haven't seen them make the kind of vacuum that the Star and Moroso vacuum pumps make. Maybe they have been improved.....I can't say being that the last one I messed with was about 3 years ago.
Re: Dry Sump System
Here are some pics of the oiling system on the new 615...
QtrWarrior- Posts : 2699
Re: Dry Sump System
Doug Rahn wrote:Quit admiring it sitting on the shop floor and get it in the car
Tomorrow OLD man !!
Re: Dry Sump System
not tomorrow it never comes just till friday you say tomorrow again so get that thing set in
Page 2 of 2 • 1, 2
» DRY SUMP OIL SYSTEM
» dry sump / wet sump ?
» DRY VS WET SUMP
» max vac on dry sump?
» Front sump vs rear sump
» DRY VS WET SUMP
Page 2 of 2
