351W problems... Problem solved!
+10
85bigblockfox
Larry Williams
kim
DaveMcLain
gmsmkr
14 posters
351W problems...  Problem solved! Empty 351W problems... Problem solved!
Post  jbozzelle May 8th 2015, 9:20 am
Guys,
Need some help here.
351W.  Basic stock rebuild.  Fired up and showed good oil pressure on gauge but rolled the cam bearings in their journals and showed lack of oil on the main and rod bearings...
Give me some things to check.  Engine is out and apart right now.  Just looking to make sure this doesn't happen again when I reassemble it....
Thanks in advance
351W problems...  Problem solved! Empty Re: 351W problems... Problem solved!
Post  gmsmkr May 8th 2015, 9:27 am
Check pick up screen and oil holes in crank journals along with the oil pump look at the plate that bolts on the pump if it has scarring it probably is no good... hope some of this helps
gmsmkr
gmsmkr
Post  rmcomprandy May 8th 2015, 9:58 am
Over the high limit dimension on the cam journals or being tapered as well.
I don't know about your 351W but, cams come that way for a 385 and some other engines, all the time. Polishing, sanding or even grinding main journals if they are over a thou to big is required in a lot of cases
With older worn-in cam bearings this does not seem to show itself.
Post  DaveMcLain May 8th 2015, 10:22 am
Did you assemble the engine using grease?  If so that can certainly cause these sort of problems. I saw this very problem on a 351 Windsor that someone put together using white grease and the engine spun the cam bearings due to lack of lubrication(grease plugged the holes).
DaveMcLain
Post  jbozzelle May 8th 2015, 10:35 am
Randy - Are you saying that the cam may have been a few thou large on the diameter? Could it be that way yet still spin freely in the journals when installed?
Dave - No, it was assembled by a local shop. But my dad and I changed the cam after it was built, but before it was fired. We used the Comp Cams cam lube with it.
Any oil gallery plugs that could be missing? The engine is at the shop and I plan to pick it up and look at it myself in a few days. It had good pressure while priming it with a drill and even had good oil flow to the rockers during priming. We're all scratching our head on this one... Only other thing I can think of is the oil pan to pickup clearance got out of whack during engine installation. Oil pan got smacked or something.
Post  kim May 8th 2015, 10:57 am
Not that the cam was oversized, the bearings themselves a little on the oversized side. Once things got warm, not enough clearance for cam and oil in bearing. As for main and rod bearing scratching... oil pickup clearance in pan. Oil pick-up to pump allowing air??? Oil pump to block mating not flush... other things, typical, block not cleaned properly before assembly and trash pumped through bearings. If there is crap left in passages after the oil filter, the only place it can go is through the bearings.
kim
Post  jbozzelle May 8th 2015, 11:45 am
How is the oil passed through the block? Where's it go after the pump? Does the cam or mains get oil first?
Post  dfree383 May 8th 2015, 11:57 am
351w oil system diagram
Post  gmsmkr May 8th 2015, 12:35 pm
351W problems...  Problem solved! Windsor_Lube_zpsauif3dz7
gmsmkr
gmsmkr
Post  Larry Williams May 8th 2015, 1:55 pm
i have had 2 problems with the 351 oiling system.
with a remote oil filter the lines can be mixed up
a sticky relief valve in the oil pump
Larry Williams
Larry Williams
Post  DaveMcLain May 8th 2015, 2:07 pm
jbozzelle wrote:Randy - Are you saying that the cam may have been a few thou large on the diameter?  Could it be that way yet still spin freely in the journals when installed?
Right but what lube was used when the lower end was put together. In the Windsor engine in my example grease was used in the main bearings where it blocked the oil to the cam bearings.
DaveMcLain
Post  rmcomprandy May 8th 2015, 4:34 pm
jbozzelle wrote:How is the oil passed through the block?  Where's it go after the pump?  Does the cam or mains get oil first?
actually ... the front cam bearing is the first to get oil, then the rest of the engine.
Post  jbozzelle May 10th 2015, 11:43 am
Thanks guys. Hoping to pick it all up from the shop this week. I'll post some good pics in hopes of figuring it all out. The engine is complete and just needs to be reassembled once I figure out why it failed.
Post  jbozzelle August 28th 2015, 10:01 am
Hey Mods - Move this to the new SBF section...
Also, should the cam journals be showing any sign of scuffing of some sort where it "grabbed" the bearing?  The cam journals look perfect!
This thing is going on the stand in a week or so and will get the oil gallery plugs pulled and the block brushes pushed through it... Hopefully I'll find a blockage............
Post  supervel45 August 28th 2015, 10:18 am
Be sure and brush the main to cam oil holes very good. I had one give me a similar issue, and those had been missed. It's better to do it while the cam bearings are out, but it can still be accomplished with them in, but is harder to do a good job.
Post  rmcomprandy August 28th 2015, 10:33 am
jbozzelle wrote:Guys,
Thanks in advance
Is this a remote oil filter...?
Where is the point of oil pressure taken...?
Post  maverick August 28th 2015, 11:07 am
Are you sure the cam bearing oil holes were correctly aligned by the builder before you swapped cams? They may have been wrong to begin with.
Post  jbozzelle August 28th 2015, 11:35 am
Thanks in advance
stock location filter and pressure taken right above filter...
Post  jbozzelle August 28th 2015, 11:37 am
maverick wrote:Are you sure the cam bearing oil holes were correctly aligned by the builder before you swapped cams?  They may have been wrong to begin with.
No clue... Thinking holes may have been off or partially covered or maybe the feed holes from main saddles were clogged... can't tell anything now since the bearings spun...
Post  85bigblockfox August 28th 2015, 11:47 am
Old engines I tear down and put rings and bearings in I take the block to the car wash. You can put the car wash wand in the filter hole and sometimes its amazing what blows out of there.
85bigblockfox
85bigblockfox
Post  jbozzelle August 28th 2015, 11:57 am
85bigblockfox wrote:Old engines I tear down and put rings and bearings in I take the block to the car wash. You can put the car wash wand in the filter hole and sometimes its amazing what blows out of there.
Yep, I do the same on the engine stand with a blow gun attachment that also pulls solvent from a jug at the same time...
Post  supervel45 August 28th 2015, 12:25 pm
That's all fine and well, but run a brush through them too. The old oils would get caked up in there real bad, and it can be very hard to clean.
Post  bbf-falcon August 28th 2015, 10:46 pm
Yes brush each and every hole in block,and clean brush w/cleaning solution after each stroke.
Post  FalconEh August 28th 2015, 11:49 pm
Were the cam journals mic'd before bearing installation? The few thou could have been on the OD
Post  maverick August 29th 2015, 12:24 pm
I'm back to the "bearings were put in wrong" idea. Since there's no sign of scuffing in the bores, maybe they didn't spin after all.Suspect
