Front drive distributor for BBF
Wheelie58
QtrWarrior
10.0
psfracer
Front drive distributor for BBF Empty Front drive distributor for BBF
Post  psfracer December 31st 2015, 10:13 pm
Has anyone run one on their BBF? I have a custom bracket already, so can I just run one for a BBC? Looks like MSD only has them for SBC and BBC.
psfracer
psfracer
http://www.psfracer.com
Front drive distributor for BBF Empty Re: Front drive distributor for BBF
Post  10.0 January 1st 2016, 1:35 am
You'll have to make a spacer made to go between danny bee cam washer and your dist drive pulley.
Then just mount the distributor where belt is straight and tight.
10.0
Post  QtrWarrior January 1st 2016, 8:54 am
Contact Keith Fulp, He had a piece at PRI that bolted to front of Danny Bee drive to spin the distrib.
QtrWarrior
QtrWarrior
Post  jasonf January 1st 2016, 2:29 pm
Keith Fulp Motorsports
Front drive distributor for BBF 12360153_1005515949490349_449821584101048983_n
Post  psfracer January 1st 2016, 3:15 pm
10.0 wrote:You'll have to make a spacer made to go between danny bee cam washer and your dist drive pulley.
QtrWarrior wrote:Contact Keith Fulp, He had a piece at PRI that bolted to front of Danny Bee drive to spin the distrib.
jasonf wrote:Keith Fulp Motorsports
Thanks guys. KFM it is.
psfracer
psfracer
Post  Wheelie58 January 3rd 2016, 1:28 pm
Thanks guys.
Yes the front drive distributor is all figured out. The one in the picture is for a Mallory distributor that the Danny
Bee shop had on hand. I believe that unit is now obsolete and the MSD distributor kit will be the best part to use. I have the bracket all figured out and CNCed the first one a few days ago. Currently, I have to buy a MSD Chevy kit and toss the bracket. Hopefully I can work a deal to have MSD provide a kit with no bracket....but I may have to buy a few to get that done.
The small parts are all in stock....drive mandrel and such.
Next step is to dyno test the setup and then put one on the 618 for my abuse. It will be sporting the setup at Hardinsburg.
I will post more info as I get it.
If anyone's interested, just give me a call at 678-458-2033 for more details.
Thanks!
Keith
Wheelie58
Wheelie58
Post  Wheelie58 January 3rd 2016, 1:47 pm
Here are a couple pictures of the MSD setup.
Just a mock up....
Front drive distributor for BBF B385085C-2E3B-4ED6-8AF0-443E9AFE6774_zpsmgiph5ql
Front drive distributor for BBF A36303AE-C4D4-4B82-A804-3057D3539D97_zpsa1z5hlg2
Wheelie58
Wheelie58
Post  psfracer January 3rd 2016, 2:36 pm
So from this pic it looks like I have the single bolt coming off of the Danny Bee belt drive. I already have a bracket, but nothing else.
Front drive distributor for BBF 598%20CID%20BBF%2012-2015
I will call you in a couple days to get it from you -- thanks for the help.
psfracer
psfracer
Post  samiam January 3rd 2016, 5:58 pm
Are you useing this set up for clearance problems, or are there any other benefits ,,, it is clean looking
samiam
samiam
Post  Wheelie58 January 3rd 2016, 6:03 pm
samiam wrote:Are you useing this set up for clearance problems, or are there any other benefits ,,, it is clean looking
Sam
In most of our cases, it is because it looks cool and may provide a little more accuracy. It also helps manifold clearance.
These drives are mandatory for the Big Boys that get lots of special grinds on custom cam cores 60 mm and larger that have no distributor gear on the cam.
Keith
Wheelie58
Wheelie58
Post  Curt January 4th 2016, 9:12 am
Keith, are you making a distrubutor plug to go with the kit?
Post  Wheelie58 January 4th 2016, 12:07 pm
Curt wrote:Keith, are you making a distrubutor plug to go with the kit?
Curt....Yes
Wheelie58
Wheelie58
Post  samiam January 4th 2016, 7:32 pm
Thanks Keith, Interesting what we dont know till we ask
samiam
samiam
Post  Wayne Pearce January 13th 2016, 10:50 am
Hey, Keith: Just a couple questions, do you have a part # for that MSD distributor, and what will your mounting kit, and distributor bore plug set me back?
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  Wheelie58 January 13th 2016, 4:27 pm
Wayne Pearce wrote:Hey, Keith:  Just a couple questions, do you have a part # for that MSD distributor, and what will your mounting kit, and distributor bore plug set me back?
Wayne,
The MSD Kit is #8520 - Summit sells it for $537. Hopefully I will get a better deal than that.
If your Danny Bee doesn't have the cam washer with the 3-hole bolt pattern on the front, you will need one of those ($44) and you will need a drive mandrel that bolts to it. That mandrel is $39. The belt, pulley and fasteners come in the MSD kit. I have not figured the price on my bracket and distributor plug, but it will be under $100.
Just call any time if you want to talk about it.
Thanks --- Keith
678-458-2033
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Post  Wayne Pearce January 15th 2016, 3:02 pm
Hey, Keith:  Just a couple more questions (sorry)  the three holes cam washer you mentioned - is that the washer that holds the Danny Bee cam pulley in place?  If so, mine only has the single hole for the pulley bolt.  I see that the MSD comes with the big block Chevy mounting bracket, would I be getting your own design mounting bracket?  In one of your pics, It looks just like what I would need, old style cast Danny Bee, with a 1/4" motor plate with your mount attached - cool!  BTW you custom milled the back of a timing cover for me to compensate for mounting a motor plate between the timing cover, and the block - it worked out perfectly!
Wayne Pearce
Post  Wheelie58 January 15th 2016, 4:19 pm
Wayne Pearce wrote:Hey, Keith:  Just a couple more questions (sorry)  the three holes cam washer you mentioned - is that the washer that holds the Danny Bee cam pulley in place?  If so, mine only has the single hole for the pulley bolt.  I see that the MSD comes with the big block Chevy mounting bracket, would I be getting your own design mounting bracket?  In one of your pics, It looks just like what I would need, old style cast Danny Bee, with a 1/4" motor plate with your mount attached - cool!  BTW you custom milled the back of a timing cover for me to compensate for mounting a motor plate between the timing cover, and the block - it worked out perfectly!
Wayne
Yes...that is the washer that the cam bolt goes through and holds the cam hub on.
I have the part with the hole pattern.
The Chevy kit comes with a Chevy bracket...can be used for a wall ornament. You would get a KFM bracket that bolts to the BBF.
Some day...if I can swing the purchase of 5 or 10 kits, I can get the Chevy bracket deleted...at a better price.
Right now, that is all we have. MSD discontinued the universal kit.
The Danny works the same, cast or billet.
Good to hear that your other parts are happy!
Please call with any questions.
678-458-2033
Keith
Wheelie58
Wheelie58
Post  Lem Evans January 15th 2016, 5:49 pm
I know that Keith knows this but, for the benefit of others.....the new D. Bee BBF kits come standard with the steel drive washer and an assortment of ARP 12 point bolts.
Post  Wheelie58 January 15th 2016, 7:35 pm
Lem Evans wrote:I know that Keith knows this but, for the benefit of others.....the new D. Bee BBF kits come standard with the steel drive washer and an assortment of ARP 12 point bolts.
It is great to see American companies like Danny Bee constantly improving their products.
Not only do they include these upgrades in new kits, the parts are readily available to upgrade existing drive kits. Lem is a great connection for Danny Bee kits and parts.
Keith
Wheelie58
Wheelie58
Post  Wayne Pearce January 15th 2016, 7:55 pm
Yeah, I've got to contact Lem soon as I need the torrington bearings for one of my Danny Bee kits. Working on my 545, I had to pull the valve train apart, and couldn't get the little 1/4 20 screws out of the retainer plate without heat (damned locktite).
I got the screws out but the torrington bearing didn't do very well.
Wayne Pearce
Post  Lem Evans January 15th 2016, 8:05 pm
Keith
Thanks for the kind words but, it's a clear case of the value going up and the price being the same.
