Engine balance
STR-LGL-70
away
Engine balance Empty Engine balance
Post  away February 27th 2017, 2:16 pm
Does anyone have a balance sheet for weighing components to figure out what bobweight to balance the crank to?
Thanks in advance
Adrian
away
away
Engine balance Empty BUMP
Post  STR-LGL-70 March 4th 2017, 10:40 am
BUMP
STR-LGL-70
STR-LGL-70
Engine balance Empty Re: Engine balance
Post  rmcomprandy March 4th 2017, 2:02 pm
I don't understand this ... How is having a "balance sheet" going to weigh components ...?
Post  cool40 March 4th 2017, 2:59 pm
What someone else's parts weigh dont necessary mean your parts are the same....even if you have the same parts! Lol
Post  BOSS 429 March 4th 2017, 5:11 pm
away wrote:Does anyone have a balance sheet for weighing components to figure out what bobweight to balance the crank to?
Thanks in advance
Adrian
Thats not how it works, diff cranks take diff weight metal,depending on rods,pistons,and such.
EXP, You have a piston in one that 110 heaver  then another ENG,all else being the same,  crank weight must change
Post  Frank Merkl March 4th 2017, 6:48 pm
here's a calculator
http://www.performanceenginetech.com/bobweight-calculator/
Engine balance Empty Balance
Post  STR-LGL-70 March 4th 2017, 8:56 pm
Thanks Frank,
I'm sure that was what Adrian was looking for, not too hard to figure out, LOL.
In my case I would like to be able to order a crank from Adney & have him balance it before shipping, once I figure out what stroke I'm going to use.
Sheldon G
STR-LGL-70
STR-LGL-70
Post  rmcomprandy March 4th 2017, 9:36 pm
STR-LGL-70 wrote:Thanks Frank,
Sheldon G
He certainly can do that but, ONLY if he has a way to know that actual Bob Weight value.
Post  away March 5th 2017, 10:44 am
Yes thanks frank that is what I was looking for. Yes I do have a scale and rod balance fixture to weigh all of my components obviously! I just lost my sheet that I used to have on excel that I could print out weigh everything and write it all down and take the sheet and crank to the machine shop for balancing. Crank grinding and balancing are the only two machine shop things I have to outsource with building engines out of my shop I have everything else actually.
Adrian
away
away
Post  Mustang-junky March 7th 2017, 12:10 am
So you need a blank sheet that you could fill in your info on?
Jess
Mustang-junky
Mustang-junky
Post  away March 7th 2017, 10:32 am
Mustang-junky wrote:So you need a blank sheet that you could fill in your info on?
Jess
Yes an excel file would be great
away
away
Post  Lem Evans March 7th 2017, 10:58 am
Engine balance 457d52be-cfd3-4a0d-ad0a-1120348c745a_zps0ba275cb
Post  away March 7th 2017, 11:11 am
Beautiful
Thanks Lem
away
away
