pro bracket radials
+6
5pointslow
biglucky
Roger Dyess
larry552
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
pro bracket radials
Has anyone on here tried the PBR yet and was it with a beadlock wheel or not. because I know you can't run screws and I tried a set and the tire is just spinning on the wheel. i want to see how they work. but it looks like I'm going to need to beadlock my wheel first
larry552- Posts : 335
Bead locks and radials
Every car
with horsepower and the set up to hook have had bead locks.
Roger Dyess- Posts : 16
Re: pro bracket radials
My first time out with the Pro Bracket Radials was the Ford race at U S 60.My junk was 1.21 60 ft with no bead locks.I know that is not as quick as a lot of others but i was more than pleased with mine.
biglucky- Posts : 213
From what I hear, pressure needs to be higher than a bias slick. Maybe low pressure is causing a weak bead bond?
maverick- BBF CONTRIBUTOR
biglucky wrote:My first time out with the Pro Bracket Radials was the Ford race at U S 60.My junk was 1.21 60 ft with no bead locks.I know that is not as quick as a lot of others but i was more than pleased with mine.
Nice 60 ft. time what's your engine specs?
Mark Miller- Posts : 1897
I ran 18 lbs at US 60 and going to add a little next time out. Mark Miller 512 a429 heads 4.22 rear gear and a 2 speed trans.
biglucky wrote:I ran 18 lbs at US 60 and going to add a little next time out. Mark Miller 512 a429 heads 4.22 rear gear and a 2 speed trans.
Are you N/A?I have A-429 heads but just 466 Cubic Inches and a C-4 3 speed and 3.73 gears!!!
650jetmech likes this post
Carb is a 1090 Quick Fuel.
biglucky wrote:Carb is a 1090 Quick Fuel.
Nice Carb and the valve covers look cool!!!!
you guys running these are you on singles up front or doubles? shocks that is
5pointslow- Posts : 1401
you guys running singles or doubles adj shocks on these
i like the idea of this tire , but having stange singles coil overs i have been leaning towards the bias slick stiff 28x10.5
Strange singles up front on mine.
Pretty sure I'm going to get a set after this season is over to try starting next year. Have heard good things about them, and would like to give them a shot.
Maxx Levell- Posts : 87
on a good sticky track they work great
You have a very nice car! Don't sell it short. It runs great. a 1.21 60 is noting to sneeze at. That was on a hot daytime track.
if you dont mind me asking were do you have your strange singles set up front with them
2 clicks from full tight
dr's wife racing wrote:biglucky wrote:I ran 18 lbs at US 60 and going to add a little next time out. Mark Miller 512 a429 heads 4.22 rear gear and a 2 speed trans.
Thanks. The old car was running pretty good that weekend, but the driver was slacking off. Struts are 3 clicks from full tight.
thanks for the info ,
new car and running index 10.00 and 10.50index
i love the idea of the radial idea but everything being new (car) and im sure be a learning curve , my guy says run a bias stiff wall slick with a tube ....but im on the fence.
i would say try the slick now because of the heat and in the cooler months try the radials
with rear singles were would you run them , buddy has a set may try some at a track rental in april
Start in the middle
larry552 wrote:Start in the middle
may try at some point , for now think i will stay on slicks for index racing ......seems from what i have seen radials work if the prep is good enough to remove shoes
Guy I did a pontiac for is planning on running 315 pro-radials. He bought wheels off Larry Hodge I beleive .Instead of the bead locks, money factor, he did an option where they knurled the inside lips of the wheel along the bead. It might have been a $30 option for each wheel, dont quote me on that. His will be a high 8 second car. He was told to glue them with the knurled being it's not a super fast deal.
TravisRice- BBF CONTRIBUTOR
Update. First outing all new car, foot braking th-400 3 speed trans all motor ....1.22 - 60ft no evidence of slipping the wheel on the rim. Will try to keep track of it a little better once he starts using the t-brake. This was after the 3rd pass on the car, no tweaking and no adjusting yet. These tires seem fast so far @ 18lb of air.
Page 1 of 2 • 1, 2
» MT 295/65/15 Radials
» slicks vs radials
» Radials vs Slicks
» SBF 4.10 1/8 Mile on 275 Radials
» New Goodyear drag radials
» slicks vs radials
» Radials vs Slicks
Page 1 of 2
