SBF Hemi
+7
DWJ64
dr's wife racing
11 posters
SBF Hemi
http://mooregoodink.com/hammerhead-hemi-peaks-928hp-427ci-sb-ford/?utm_source=ActiveCampaign&utm_medium=email&utm_content=MGI+News+Brief+Issue+%2352&utm_campaign=MGI+News+Brief+Issue+%2352+ALL
Makes a guy wanna go small block almost. Awesome pieces.
windsor- Posts : 1167
Re: SBF Hemi
windsor wrote:http://mooregoodink.com/hammerhead-hemi-peaks-928hp-427ci-sb-ford/?utm_source=ActiveCampaign&utm_medium=email&utm_content=MGI+News+Brief+Issue+%2352&utm_campaign=MGI+News+Brief+Issue+%2352+ALL
Thanks for the link,looks b** a** and makes a bunch of horsepower[are you sure it's only 427 cubic inches]got a kick out of that!!!
Mark Miller- Posts : 1897
Re: SBF Hemi
That is a cool engine. When they did the first build as a Street Pump Gas engine, I sent that article to my older brother. For the past 30 or 40 years he has been wanting to build a '23 T Bucket with a cool engine. He has been on the phone talking with Greg Brown at Hammerhead about building the street version for his '23. I don't know when he will get started, but the past few years he has been collecting parts for it. When he pulls the trigger on the engine, I'll definitely put up some post on it.
Re: SBF Hemi
I have a friend that runs a Yates head SBF. He is considering changing to these. They are a pretty cool piece for sure.
Re: SBF Hemi
I'm building a 12.5 to 1 445 cid with these heads. Waiting on rotating assembly now. I hope it makes decent power....
DWJ64- Posts : 9
Re: SBF Hemi
DWJ64 wrote:I'm building a 12.5 to 1 445 cid with these heads. Waiting on rotating assembly now. I hope it makes decent power....
Keep us updated!
I believe the owner/designer of them made about a 1000hp with a SBF in race configuration.
Re: SBF Hemi
I think the story said it made 928 hp on a single carb!! And that was "just" a 427 inch motor. A 445 would more impressive still.
Imagine it with forced induction!!
BBFTorino- Posts : 987
Re: SBF Hemi
Greg Brown of "Hammerhead" has also installed those heads on an LS engine with just machining a slightly different head bolt pattern and using pistons to match so, now he sells them both ways.
Edit: They made a really good package at the Race Engine Challenge contest.
Re: SBF Hemi
Thought about adding a F-2.....BBFTorino wrote:I think the story said it made 928 hp on a single carb!! And that was "just" a 427 inch motor. A 445 would more impressive still.
DWJ64- Posts : 9
Re: SBF Hemi
Any updates on this?
jasonf- BBF CONTRIBUTOR
SBF Hemi
No updates, I have everything machined and in the boxes but been busy with my old truck.
https://www.youtube.com/watch?v=YBLZaelVHuY
DWJ64- Posts : 9
Re: SBF Hemi
DWJ64 wrote:No updates, I have everything machined and in the boxes but been busy with my old truck.
Cool Video that truck leaves hard what's the engine and drivetrain specs on it?
Truck
The video below it had a 521 with cast crank forged flattops H beams and a old set of A-429 Cobra Jet heads. Has Dominator with a Sledgehammer plate with a powerglide. We changed to SBF for the last race. The Hemi will eventually go in it. Video above is with the small block.
https://www.youtube.com/watch?v=_YNFEW1Xk7g
DWJ64- Posts : 9
Re: SBF Hemi
DWJ64 wrote:The video below it had a 521 with cast crank forged flattops H beams and a old set of A-429 Cobra Jet heads. Has Dominator with a Sledgehammer plate with a powerglide. We changed to SBF for the last race. The Hemi will eventually go in it. Video above is with the small block.
Thanks almost lost it on that first pass,was that the guy that goes buy Copperhead on here with the Ford truck in the other lane?
Re: SBF Hemi
That was him. His truck runs good! We were hoping he would have came back for the last race.
DWJ64- Posts : 9
Re: SBF Hemi
Pretty cool vids!! Beating up on all the Chevy's there!!
Re: SBF Hemi
IMO that truck needs a wing.
rbro460- Posts : 102
Re: SBF Hemi
I finally finished getting the Hemi together and to the dyno. It made 803 hp at 7300 and over 600 ft lbs from 4000 up. I will have to look at dyno sheets for exact numbers. Heads are out of the box and untouched with flat top pistonsjasonf wrote:DWJ64 wrote:I'm building a 12.5 to 1 445 cid with these heads. Waiting on rotating assembly now. I hope it makes decent power....
DWJ64- Posts : 9
jasonf and Mark Miller like this post
Re: SBF Hemi
DWJ64 wrote:I finally finished getting the Hemi together and to the dyno. It made 803 hp at 7300 and over 600 ft lbs from 4000 up. I will have to look at dyno sheets for exact numbers. Heads are out of the box and untouched with flat top pistonsjasonf wrote:DWJ64 wrote:I'm building a 12.5 to 1 445 cid with these heads. Waiting on rotating assembly now. I hope it makes decent power....
There's one of Those 445 HammerHeads in Texas I saw This Year.
That Would Not Happen to be Your's Would It?
supervel45- Posts : 4464
Re: SBF Hemi
supervel45 wrote:DWJ64 wrote:I finally finished getting the Hemi together and to the dyno. It made 803 hp at 7300 and over 600 ft lbs from 4000 up. I will have to look at dyno sheets for exact numbers. Heads are out of the box and untouched with flat top pistonsjasonf wrote:DWJ64 wrote:I'm building a 12.5 to 1 445 cid with these heads. Waiting on rotating assembly now. I hope it makes decent power....
Unfortunately not mine is still on the engine stand. I'm hoping to get it in in a coupe of weeks
DWJ64- Posts : 9
Re: SBF Hemi
This One Was On a Stand Too.
Yours Sounds Very Nice Also. Not Sure of The HP or The One Above. Will Check Next Chance.
» Ford's Hemi "The Original Hemi"
» out with the old and in with the ....hemi
» Boss Hemi,SOLD !
» PLEASE POST PICS OF YOUR ENGINES !!
» Early 392 hemi crankshaft
» Boss Hemi,SOLD !
