BBF Engine Block That can handle 4.65-4.7 Bore
litshoot
4speed390
Page 2 of 2
Page 2 of 2 • 1, 2
Re: BBF Engine Block That can handle 4.65-4.7 Bore
https://www.facebook.com/commerce/listing/731848765037248/?media_id=0&ref=share_attachment
I put the JC50 link here to. Maybe he can help you sourcing parts.
supervel45- Posts : 4498
I don't know if you saw this one, or if I linked it before, or if you got something else?
https://www.facebook.com/marketplace/item/2473865189483709/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Ae037bf6a-0aa3-498d-84bf-c1ea7ef415e4
Looks like the one in the in the above post Sold for 36K or less. For exotic stuff like this it may have been the best deal going I have seen so far.
supervel45 wrote:I don't know if you saw this one, or if I linked it before, or if you got something else?
I did see this one before and have spoken to the guy about them.
4speed390- Posts : 25
A bit late but didnt see it mentioned and always wondered if an oversized "sleeve" or liner in block could be put into a block. thinking similar to big diesels where its got a lip that pinches between head and block surface to support the top. would probably need some extra work at bottom to keep it aligned. Need people more knowledgeable than me to see if its possible. believe most of the diesels are designed specifically but may be able to modify. they used to make block spacers to make tall decks so theirs been weirdness done in past.
litshoot- Posts : 103
litshoot wrote:A bit late but didnt see it mentioned and always wondered if an oversized "sleeve" or liner in block could be put into a block. thinking similar to big diesels where its got a lip that pinches between head and block surface to support the top. would probably need some extra work at bottom to keep it aligned. Need people more knowledgeable than me to see if its possible. believe most of the diesels are designed specifically but may be able to modify. they used to make block spacers to make tall decks so theirs been weirdness done in past.
Anything could be done with enough money dumped into it, but their are billet aluminum custom blocks that can be taken to the limit in any direction you desire and they are properly engineered to be strong.
BOSS 429 likes this post
Page 2 of 2 • 1, 2
» Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» 4.460 bore ,70 model block
» SVO BLOCK 4.600 BORE
Page 2 of 2
