2-8 swap on cam
2-8 swap on cam
My question of the day is about a 2 and 8 swap on a new cam.
A little back story. A lifter failure pretty much wipped the bottom end of my 533 at the end of 2021 including the cam. The machine shop I use, rebuilt the engine and went with a cam that was a good bit smaller then the first cam. New cam specs are .752/.748 duration 275/285 @.050, 110 lobe sep. Intake lobe degreed @106. Old cam was .809/.817, duration 282/292 intake @108, lobe sep 110.8.
Now that I have ran the new cam for 2023, I have been wondering if some hp/tq has been left on the table so I reached out to a few cam companies to see what they recommend. Once company responded with 276/286@.050", .500"/.485" Lobe Lift, 115 LSA, 112 ICL, 2/8 Swap, firing order.
I am familiar with the firing order swap on SBF's, but havent heard of it on the BBF. What do you guys think about it?
Re: 2-8 swap on cam
HorsinAround wrote:My question of the day is about a 2 and 8 swap on a new cam.
That is the same firing order swap as a 4 -7 on a Chevrolet engine. That swap was originally done in a small block Chevy engine by "Nickens & Brown" to more equalize the cylinder/chamber temperatures.
It is a Flat-head Ford firing order.
» Motor Plates
» Fox swap 460 oil pan
» Aod swap?????
» 460 to 429 C6 swap
» Need some help on a swap MEL to BBF
» Aod swap?????
