Motor is going on dyno next week want to guess the Hp
+13
650jetmech
AndyF
maverick172
rmk57
manofmerc
Albert Clark
17 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Motor is going on dyno next week want to guess the Hp
So what about that mid track plane of whatever it was the 472 had, all that go away? I will go out on a limb, and ass/ume it did.
How high does the torque convertor flash now?
supervel45- Posts : 4464
Congrats on the PB. I’m looking for about the same out of of my car. We’ll find out next weekend hopefully.
650jetmech- Posts : 32
supervel45 wrote:So what about that mid track plane of whatever it was the 472 had, all that go away? I will go out on a limb, and ass/ume it did.
I'm setting up to run bracket class so I had 2 step launch down 3k to 3200 vs 4200 we use on .400 pro tree in past
I honestly feel the old motor planned out earlier due prob running out of cam at some point . I'm not sure no complaints of old combo though . I was doing my nhra license runs today and I shifted at 6200 at the 9.36 pass
I'm going to be pulling the old cam from the old block , it's still in great shape and I have all lifters in a wooden box labeled and made recessed holes to hold them in order to go on what cam lobe . If you or someone else on here would like to have it and would just pay the shipping I would donate it an dpay it forward . I have cam card as well
5pointslow- Posts : 1401
650jetmech wrote:Congrats on the PB. I’m looking for about the same out of of my car. We’ll find out next weekend hopefully.
Oh nice I see your location is CT do you go to New england dragway or lebanon valley ?
5pointslow wrote:650jetmech wrote:Congrats on the PB. I’m looking for about the same out of of my car. We’ll find out next weekend hopefully.
I go to LVD because its about an hour closer.
5pointslow wrote:rmcomprandy wrote:5pointslow wrote:I just went 9.36 at 143 felt awesome
Went through at 7k rpm
5.96 1/8th mile
You certainly hit you mark, right between 9.30 and 9.40.
Great job.
Thanks I appreciate it felt great
Only thing that worried me was after a pass oil is hot if it idles at 1200 rpm oil pressure is in the
Mid 30s but as soon as I touch throttle it goes to 55 to 60 . Has kaase pump and probably nothing to worry about just saw that
Like 35 at hot oil 1200
Say 55 to 60 at 2k on up
Is the block filled?
Mark Miller- Posts : 1897
Mark Miller wrote:5pointslow wrote:rmcomprandy wrote:5pointslow wrote:I just went 9.36 at 143 felt awesome
5.96 1/8th mile
Great job.
No fill in block
Great numbers there. Glad you are back on the track. Got it below 9.50 mark time to look for 8 second time slip!!! Nice build.
lance flake- Posts : 140
lance flake wrote:Great numbers there. Glad you are back on the track. Got it below 9.50 mark time to look for 8 second time slip!!! Nice build.
Thank you appreciate it
Had some killer air today
Around 4pm today I shifted higher 6800
Went 1.33 60ft
5.88 in 1/8th
No 1/4 mile due to Temps
Went 1.33 60ft
5.88 in 1/8th
Mark Miller and 650jetmech like this post
5pointslow wrote:Had some killer air today
Went 1.33 60ft
5.88 in 1/8th
Nice that should be at least 9.20's in the 1/4!! It was also cold here in Northeast,Ohio today it didn't get up to 50 until later in the day.I cut the grass in the morning and it was only in the low 40's and my nose was running!!
So i checked lash before last race and looked good . I want to get a interval schedule down like plugs and oil and lash
with my cam
Cam is a kaase k1 low lift
.731/.727 lift
109 separation
Duration at .050 272 and 280
I have Harland sharp stud mounts with jomar girdles ( i wish i went shafts ) as I'm sure overall would be more stable
how often should i be checking lash ? This is my first solid roller if it matters i go through traps at 7k rpm
Thnaks
Andy
with my cam
.731/.727 lift
109 separation
Thnaks
Andy
5pointslow wrote:So i checked lash before last race and looked good . I want to get a interval schedule down like plugs and oil and lash
with my cam
.731/.727 lift
109 separation
Thnaks
Andy
If the lash changes more than a thou or so, something is wearing out.
There is no set intervals so, just whenever you can take the covers off to check the springs once in a while.
650jetmech likes this post
» dyno next week any hp guess's ///rod picture damage and dyno sheet added
» Dyno day tomorrow, guess-timates?
» Finally...Engine goes on the dyno next week....
» dyno numbers on my new motor
» Tuning a methanol motor . Help I'm heading to the Dyno
Page 3 of 3
