Boss crank snout.
Boss crank snout. Empty Boss crank snout.
Post  fordmonsta January 27th 2024, 3:02 pm
If a guy was going to order a crank, and decided he wanted a boss snout length, do you need a specific timing cover?
fordmonsta
Boss crank snout. Empty Re: Boss crank snout.
Post  dfree383 January 27th 2024, 3:03 pm
Not to my knowledge, but you will use a specific damper, not the regular 429-460 one.
Post  rmcomprandy January 27th 2024, 8:01 pm
fordmonsta wrote:If a guy was going to order a crank, and decided he wanted a boss snout length, do you need a specific timing cover?
A lot of people use a "small Block" length snout and use a small block damper ... it uses no spacer on the front.
Post  Paul Kane January 27th 2024, 8:23 pm
Yes, OEM timing covers can be used, as can OEM balancers as well, however the crankshaft spacer needs to be shortened relative to the overall reduction of the snout length itself. As Randy noted, short-snout engines are of a performance level where a different balancer is typically utilized anyway. But yes, an OEM balancer can fit.
Boss crank snout. Jf545_11
Boss crank snout. Jf545_12
Boss crank snout. Jf545_10
QtrWarrior likes this post
