elasticity of a a set of titanium valves in a set of C heads
elasticity of a a set of titanium valves in a set of C heads Empty elasticity of a a set of titanium valves in a set of C heads
Post  chocorings January 31st 2024, 3:11 pm
hi was wondering how long would you expect a set of titanium valves to last in a set of C heads?
and what is the biggest push rod you can fit into a C head before running into trouble?
thanks
chocorings
elasticity of a a set of titanium valves in a set of C heads Empty Re: elasticity of a a set of titanium valves in a set of C heads
Post  rmcomprandy January 31st 2024, 7:23 pm
chocorings wrote:hi was wondering how long would you expect a set of titanium valves to last in a set of C heads?
thanks
What is the valve seat material and do the valves have a hard-coated seating area ?
Post  BOSS 429 February 1st 2024, 2:53 am
thanks
Pushrod will depend on a few things, lifter ,straight or off set, rocker brand and pushrod size , For exp. with WW'S shaft system you will have to do some work in the pushrod holes for the intake . Depending on port work it can get very thin.
Post  dfree383 February 4th 2024, 11:50 am
With off set lifers my 638 set needed clearanced for 7/16 pushrods
BOSS 429 likes this post
