460 7/16 cam bolt torque specs
460 7/16 cam bolt torque specs Empty 460 7/16 cam bolt torque specs
Post  maverick172 March 12th 2024, 10:58 am
i know this answer has been posted before . i am useing a grade 8 bolt with a super thicked hardened washer i forget what the torque specs is on this bolt i know guys say 80# useing a rod bolt but this is a grade 8 bolt and the standard says to torque to 78# what you guys think . thanks
maverick172
460 7/16 cam bolt torque specs Empty Re: 460 7/16 cam bolt torque specs
Post  rmcomprandy March 12th 2024, 7:45 pm
maverick172 wrote:i know this answer has been posted before . i am useing a grade 8 bolt with a super thicked hardened washer i forget what the torque specs is on this bolt i know guys say 80# useing a rod bolt but this is a grade 8 bolt and the standard says to torque to 78# what you guys think . thanks
Coarse or fine thread ? ... fine thread with a 8740 rod bolt = 75/80 lbs. Regular grade 8 = 70/75 lbs.
Grade 8 coarse thread 68/72 lbs.
jeffgfg and maverick172 like this post
