E85 street use
E85 street use
Is anyone here running or has ran E85? Thinking very seriously about picking up a carb here locally but I’ve never ran it in a carb vehicle. This will be a street driven 460 w 9.5ish static comp. Pros and cons?
curiousgeorge- Posts : 190
Re: E85 street use
I've been running E85 both on the street and and at the track for over a decade. The main reason for using E85 was that I could raise the compression to 14 to 1 thereby making power. There are benefits on a low compression build as well. It's a cleaner burning fuel with a lower EGT that reduces the cooling load and makes more power especially low end torque.
Some fuel systems are not compatible with alcohol. You will burn 25% more fuel than gasoline. At the pump in northern climates they migrate to E70 in the winter which may be a tuning issue but late spring to fall I find that it tests to be 83 to 87. I had a bad load once that seemed to have water in it. I now only buy from gas stations that have good turnover rates.
Dave De- Posts : 795
Re: E85 street use
IMO at 9.5:1 it would be a waste of time, their is no cost savings over pump gas.
Now bump the compression up to 12:1 now it’s worth looking at.
e85
i use e85 in my flexfuel pick up.e85 2.30 a gallon and 87 crap is 4.19 a gallon,so there is a savings at fill up for sure.
but my truck is stock.i have a 572 in a mustang that i bought some 110 for it and that was $105 for 5 gallons.if i keep it i will convert to e85 for sure!
hbstang- Posts : 365
Re: E85 street use
hbstang wrote:i use e85 in my flexfuel pick up.e85 2.30 a gallon and 87 crap is 4.19 a gallon,so there is a savings at fill up for sure.
It's cheaper than 87 but the fuel mileage is worse on E85 than 87!!
Mark Miller- Posts : 1950
» So…? K-B pistons have mutable top ring gap setting why then is there such a big difference in gap between street and tow. 4.400 x .0065=.028 street
» AN fittings for street street car (brakes)
» Getting my street car
» CAMS ? STREETABILITY
» 6.50 street car
» 6.50 street car
