Best Electric Water pump
QtrWarrior
650jetmech
For those of you drag racing and running an electric water pump, which brand do you run. I just had my Moroso unit fail and got my new engine up to 230* before i caught it. After doing some research it seems these pumps are only good for 2 to 3 yrs. At almost $600 for this part I’d like to try a different Mfg. Any thoughts? And no I dont want to go to a mechanical pump, I like being able to cool the engine down between rounds.
650jetmech- Posts : 33
water pump
you can buy cheap,or you can buy good,but you cant have both.
my money is on maziere.they can rebuild them,not so with cheap ones.
hbstang- Posts : 365
650jetmech likes this post
Re: Best Electric Water pump
I’m all for good. No cheap on my car. I’ll look into the Meziere, thanks.
dfree383 and Dave De like this post
I have an electric moroso old school drive connected to a mechanical pump. The only time i had any problems was i over tightened the belt once and burned up the bushing. As long as you leave the belt loose it works great. Its a cog belt so no need for it to be tight. The one i burned up was a hand me down probably 20+ years old. The new one is going on 5 or 6.
stanger68- Posts : 499
Mark Miller and 650jetmech like this post
https://www.northerntool.com/products/wayne-12-volt-self-priming-transfer-water-pump-340-gph-3-4in-port-model-pc1-108559
Been using one of these or something similar since 1998....
QtrWarrior- Posts : 2702
Curt likes this post
I have a Mr. Gasket Electric that I have used on the dyno engines for the last 15 years or so with no issues.
Maybe it has a lot to do with environment.
Since you asked about the "best", then there is only one answer; Meziere.
R,
HAP
R,
HAP
HAP2- Posts : 3
hbstang and 650jetmech like this post
not mine
https://www.ebay.com/itm/176032576621?itmmeta=01HVWNYMA9T2K84GAYZNY17YW4&hash=item28fc5bf46d:g:dpQAAOSweohlU57g&itmprp=enc%3AAQAJAAAA0HpAyc1s3C0R9TeoYveLp%2FsChGfgBBt%2BD2kyLHH85tdSQtFxRSORc6O9wPnDj9jGzvx937gNOQ24j04cTmXLc4kD%2FyRDFd9eBvzfhmjx%2Fb7gpazmojVXFeIVbO03ojC6ASO%2FiyCdUrmdkEGRr02n1KLJ9bDL1JqrD0D5p3YD32oag%2FLtI3HmPO3WWdXb013RfJGODsNOMne%2FntB1uTCCGYI4auBfwszw6RUeoDOd%2Br%2FpGeMIij3S26Mfs%2FjEV7rf0tGjVRTcIe%2FFTdeVLNHoNxI%3D%7Ctkp%3ABk9SR6TF-pXfYw
At 35 gpm would that have enough volume to use on a street car for occasional street use?
rmk57- Posts : 176
» Switched from mech water pump to Moroso electric water pump
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» BEST ELECTRIC WATER PUMP
» Electric water pump
» wtb Electric water pump
