Race Engine Weights
+23
2fox
peganit2
D-CEL
Larry Williams
Kevin93
brianhaeckel
665 falcon
deliveredfast
511Fox
jts557
racnrick
27 posters
Race Engine Weights - Page 2 Empty Re: Race Engine Weights
Post  Kevin93 March 28th 2010, 10:36 pm
An IDT Eliminator block with a 4.680 bore, bronze lifter bushings installed & LSM CNC litening program weighs approx. 204 lbs without the roller cam bearings installed. Thanks & have a nice night!!!!
Kevin93
Post  bruno February 6th 2011, 9:22 am
any updated info ???
http://WWW.CKRME.COM
Post  Larry Williams February 6th 2011, 11:19 am
c.evans wrote:Guys,
I've been doing some checking lately, with an very accurate and zeroed 1000 lb scale, of the BB Ford engines we've had going on the dyno lately. All engines were weighed without flexplate or starter, but with oil, carb and etc . In other words I've made sure that the comparisons are valid.
1. Bobby's engine. DOVE-A block, 4.442" X 4.500" = 559 CID, Milodon splayed 4 bolt main caps, P-51 heads, Victor, single 1250 QFX carb, Mezeire electric water pump. 600 lbs.
2. Mike's engine. FRPP SVO block, 4.420" X 4.300" (I think? Lem?), P-51 heads, Victor, single QFT carb, water pump. 641 lbs.
3. Todd's engine. FRPP SVO block, 4.600" X 4.500"= 598 CID, TFS A-460 heads, TFS 2 X 4 tunnel ram manifold, two QFT 1150 carbs, Mezeire electric water pump, Moroso vacuum pump, dry sump pump and lines, Peterson dry sump tank, & nitrous plumbing. 735 lbs.
4. Jeff's engine. DOVE-A block, 4.440 X 4.500"= 557 CID, short fill HardBlok, Milodon splayed 4 bolt main caps, TFS A-460 heads, TFS single four intake manifold, alum. mechanical water pump, single QFT carb. 627 lbs.
I hope this is helpful,
Charlie Evans
Where is number 5 Charlie? I need to order front springs as I am replacing the old gabriels on there now and the weight would be a huge help.
Larry
Larry Williams
Larry Williams
Post  c.evans February 12th 2011, 12:14 am
Larry,
To answer your question,,,,,engine # 5 is an all alum. block 598 CID engine with TFS A-460 18 bolt heads and a TFS single plane intake manifold. Complete with carb, oil, flexplate, internal Kaase oil pump, vacuum pump but no starter,,,,it weighs 556 lbs.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Larry Williams February 12th 2011, 12:36 am
thanks charlie thats just what I was looking for.
Larry Williams
Larry Williams
Post  D-CEL February 17th 2011, 4:28 pm
Hey Guys,
Fantastic! I can contribute too! LOL
My unmachined A96 weighs 160lbs
Jason
D-CEL
D-CEL
nascar429 likes this post
Post  peganit2 May 30th 2011, 11:08 pm
What made that first engine comparatively lighter then the rest?
peganit2
Post  peganit2 May 31st 2011, 4:00 pm
Talked to some chevy boys about that 600# number, and the 559 cubes. They were pretty quiet. Cool
peganit2
Post  c.evans May 31st 2011, 6:25 pm
peganit2 wrote:What made that first engine comparatively lighter then the rest?
Answwer;
1. The block was a stock production block and it was lighter than the aftermarket blocks.
2. The alum. P-51 heads are fairly light in weight. They are an OEM style CJ head.
3. The FRPP Victor single plane intake manifold was lighter than the bigger A-460 or C-460 single planes.
4. The #1 engine that was weaighed was Bobby Shrewsberry's engine and he won Super Pro at the 2010 Ford bash with it.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  peganit2 May 31st 2011, 6:54 pm
Answwer;
Hope this helps,
Charlie
Not sure. The next lightest with p51's is +41#.
Any more reasons why #1 was that much lighter?
peganit2
Post  peganit2 May 31st 2011, 7:02 pm
I would LOVE to get a BBF around 600lbs for my Fox Mustang, and I just want to know what it takes.
peganit2
Post  c.evans May 31st 2011, 10:04 pm
Engine #2, (Mike's) had P-51 heads, but the 41 lb. difference in engine weight can be attributed to the SVO A-460 block. That's Ford aftermarket racing block with really thick cylinder walls and siamese cylinders, also a beefier bottom end.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  peganit2 June 1st 2011, 6:50 pm
c.evans wrote:Engine #2, (Mike's) had P-51 heads, but the 41 lb. difference in engine weight can be attributed to the SVO A-460 block. That's Ford aftermarket racing block with really thick cylinder walls and siamese cylinders, also a beefier bottom end.
Charlie
Oh sorry missed that little detail. Embarassed
Excellent information!
peganit2
Post  2fox January 6th 2012, 10:13 am
Have you ever weighed a 408 W ? With stock block.super victer intake.victer jr heads.ect?
I would like to know how much heavier the bbf would be thanks
2fox
Post  rmcomprandy January 6th 2012, 11:38 am
2fox wrote:Have you ever weighed a 408 W ? With stock block.super victer intake.victer jr heads.ect?
The published shipping weights of FRPP crate engines which also include the pallet:
392 "Z" engine = 545 pounds
521 with A460 block = 700 pounds
514 with production block = 670 pounds
Post  G-Code January 9th 2012, 1:30 pm
Race Engine Weights - Page 2 BoatengineatRandys
565", A-460 block, A-460 heads, Crower/SVO 4.25" stroke crank ( 76 lbs) weight as seen 620 lbs. Weighed on two certified scales.
G
Post  bbf coupe December 12th 2012, 9:35 pm
New to site!! I love it,Thanks for the info...I was wondering what a dressed 460 based motor would weigh..
Thanks again!!
bbf coupe
Post  2fox February 21st 2013, 6:37 am
What about an aluminum block ?.with aluminum heads built up?
am.just wondering if it would.weigh about the same.has a stock Ford block 408w with aluminum heads.
LMK
2fox
Post  dfree383 February 21st 2013, 7:24 am
take 50-60Lbs off the cast stock block builds and maybe upwards of 75-85lbs off the A460 block builds.
Post  2fox February 21st 2013, 3:39 pm
Last edited by 2fox on February 24th 2013, 1:16 pm; edited 2 times in total (Reason for editing : assholes)
2fox
Post  fatal addiction September 5th 2013, 8:27 am
Any idea what the aluminum blocks weight?
fatal addiction
fatal addiction
Post  Larry Williams September 5th 2013, 10:48 am
as per C. Evans
Larry Williams
Larry Williams
Post  D-CEL October 17th 2013, 12:21 pm
"by fatal addiction on September 5th 2013, 5:27 am
Any idea what the aluminum blocks weight?"
My un-machined A96 is 160lbs
probably 115-120lbs @ 4.600
Jason
D-CEL
D-CEL
Race Engine Weights - Page 2 Empty very interesting info here.
Post  OkieDave November 1st 2013, 11:55 am
This is very interesting. I had always been told the Fords were heavier than chevies but maybe that isn't true. Lately I'm playing with LS motors and turbo's. here's a surprise, an Iron LS block is about as heavy as an Iron BBF. the complete engine is Lighter I think but even an alum LS block isn't much lighter than alum BBF block.
OkieDave
Post  fstrthnu373 July 23rd 2014, 12:29 pm
588 10.3 deck aluminum CC block, billet crank, aluminum rods, 18 bolt A460 heads, WW rockers, TFS single plane intake, 7 quart steel pan full of oil, Fogger with trash can noids, mid plate, motor plate, flywheel, wet sump with moroso external oil pump, timing belt drive, distributor, csr electric water pump, aerospace vacuum pump. 539lbs
fstrthnu373
fstrthnu373
