Cometic MLS head gaskets
+19
10SHOTS
GT300TD
stanggt
dirt_worker
Art
powerstrokeace
Larry Williams
Maxx Levell
342g
prosandguy
jpb6061
83-88T-Bird Guy
mustangjeff
23 posters
Page 6 of 6
Page 6 of 6 • 1, 2, 3, 4, 5, 6
Re: Cometic MLS head gaskets
Lem Evans wrote:I have no idea what Nagy is so I cant really compare them.
I heard about them on this forum before I found out that you had Cometic intake gaskets (Thread-plastic intake gaskets, David Cole). How much are the Cometic intake gaskets. I do want a set of head gaskets though, 4.50 bore ,.040 thick let me know the price plus shipping to Lancaster Ohio, 43130.
GT300TD- BBF CONTRIBUTOR
Got my Cometic head and intake gaskets today. Thanks Lem. It was good talking to you also
c-5667-045s on the way , thanks
10SHOTS- Posts : 587
Lem, I need 2 of these:
C5668-060 please... let me know if you have them or if you need to order them.
Terry
972-533-5341
Thanks Lem, gaskets came in today!!
Terry
972-533-5341
A460 block 572' with 10 bolt A460 heads, which Cometic?
I'm finally finishing my new pump gas street motor. It's a 4.5" bore A460 block that has the 18 bolt head bosses at the deck surface. I'm using a set first generation 10 bolt A460 heads with 2.350" intakes 'rubbed on' by Charley that I bought from Lem ten! years ago. I've been very happy with the Cometic's and will use the .045 compressed thickness to keep us at 11:1 static CR. The question, which version of the BBF gasket, 18 bolt or conventional 10 bolt?
CDMBill- Posts : 182
You may use the 10 bolt gaskets with the 10 bolt heads......they are cheaper that the 18 bolt versions.
You know I over think things. Any issue with using the 18 bolt in a pinch? I want to buy a spare set for both engines. Any feedback on the MLS header gaskets? I need two pair of the 2.25's for A460's.
In this application either style would work for you.
If you want to standardize your spares just keep plenty of the 18 bolt style.
10 bolt head gaskets
I am looking for some .040 head gaskets. The bore is 4.650 and the heads are 10 bolt. Can you help me with this?
Mark
Mark
mao66fairlane- Posts : 6
10SHOTS likes this post
Give BF Evans Ford a call, they probably have them in stock
2 wicked- Posts : 211
mao66fairlane wrote:I am looking for some .040 head gaskets. The bore is 4.650 and the heads are 10 bolt. Can you help me with this?
Mark
Sure, 270-929-5295
» Cometic MLS head gaskets
» Cometic Head Gaskets
» COMETIC HEAD GASKETS NEW IN PACKAGE $175 SHIPPED
» COMETIC HEAD GASKETS: 4.640 bore .060 thick SOLD
» Cometic Gaskets
» Cometic Gaskets
Page 6 of 6
