Crank mandrel advise
cubicgator
Crank mandrel advise Empty Crank mandrel advise
Post  cubicgator April 27th 2011, 10:57 pm
Switching to belt drive fuel pump have 3 bolt ati balancer, have a v belt for alternator, need 1 inch mandrel
thanks wally
cubicgator
Crank mandrel advise Empty Re: Crank mandrel advise
Post  BOSS 429 April 27th 2011, 11:05 pm
CALL PETERSON PUMP
Post  David Cole April 27th 2011, 11:21 pm
I've got a Ron's mandrel on my 598. I use it with an ATI 3 bolt damper (BBC pattern) 5 1/2" East Coast Auto Electric BBC V belt pulley, a BBF crank trigger wheel and two 18 tooth pulleys for the fuel pump and vac pump. Keith Fulp made me a nice adapter that keeps everything centered. The V pulley and mandrel would have been centered, but it throw a wrench inthe works with the BBF crank trigger wheel.
Crank mandrel advise Drive
Post  c.evans April 28th 2011, 1:43 am
I run a ATI BB Ford dampner on Krisse's engine, and then a Stefs BB Ford 1" mandrel with a keyway. It has several bolt hole patterns. The Stefs has small block Ford 3 bolt, big block Ford 4 bolt, and then Chevy 3 bolt.
Hope this helps,
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Wheelie58 April 28th 2011, 6:07 am
Wally,
Peterson makes a good selection of mandrels that will fit your need. The complications come in to play if the balancer that you have does not allow all of your pulleys and crank trigger wheel to center up accurately. If you have a ATI with a 3-bolt Chevy pattern and Chevy front, and no crank trigger, you can just buy a Peterson (or other) Chevy mandrel and it will center up in the 2.280" Chevy register hole and line up with the bolt pattern.
If you have a Ford crank trigger, you will need something to center it in the Chevy register and also fit with whatever mandrel that you choose. ( I custom make those parts )
The mandrels that bolt on to the Chevy pattern (3-bolt) will cover up your Ford crank bolt and may cause interference and complications.
The mandrels that use the crank bolt to attach them are more common and less expensive. The one to fit a Chevy balancer will need to be drilled out to accommodate the larger diameter Ford bolt.
I have a small selection of mandrels on hand, new and used for Ford and Chevy and can get the Peterson parts and do any modification that you may need.
There are many options and price ranges on this simple little part. Aeromotive, Moroso, Canton, Stefs, Ron's...and others all make good parts.
If you need any help with this, just give me a call.
Keith Fulp
www.KeithFulpMotorsports.com
678-458-2033
Wheelie58
Wheelie58
Post  cubicgator April 28th 2011, 2:28 pm
thanks alot guys, don t run a crank trigger, got a dual sync, called rons, just what i needed already shipped thanks ALOT!!!
cubicgator
Post  bbf-falcon April 28th 2011, 7:01 pm
cubicgator wrote:thanks alot guys, don t run a crank trigger, got a dual sync, called rons, just what i needed already shipped thanks ALOT!!!
Can be a pain. Like keith already said,the big Ford crank bolt kinda throws a wrench in the fire. Just went through all of this just a few weeks ago. Good luck brother Wink
Post  cubicgator May 5th 2011, 12:12 am
Got my rons mandrel today PERFECT!!!! thanks again for advise
cubicgator
Post  Wheelie58 May 5th 2011, 7:01 am
Yeah...they make a nice piece.
You will have many years of enjoyment with it.
Keith
Wheelie58
Wheelie58
