Need lots of stuff for my 557 fox stang
I need 9inch case witch will work for 35 spline axles, also spool, need fox 460 oil pan , need 400 th bell to 460 sfi appr. and manual rac.. need more but too mutch to list.....pm me if you have some suff i need thanx .............
JT557- Posts : 111
Re: Need lots of stuff for my 557 fox stang
check with bbF-falcon for the 9" case . he has one and not going to use it . He got it from me with no pic's sent .
DanH- Posts : 1081
9" parts
JT557: I just switched to 40 spline axles in my mustang and have my 35 spline parts for sale.Its a nodular center section with an aluminum pinion support for a big 35 spline pinion,Mark Williams 35 spline spool and axles,axle brgs are for the large Ford housing ends[3.150],Axles fit 38.625" flange to flange and have dual wheel patterns 4.5 tapped for 1/2 studs and 4.75 tapped for 5/8 studs.A large pinion yoke for 1350 U-joint,I want $700.00 for parts.Thanks Pat
dave d- Posts : 809
