Anyone know the specs of a Ford Motorsport E3ZM-6015-A351 Block.
Anyone know the specs of a Ford Motorsport E3ZM-6015-A351 Block. Empty Anyone know the specs of a Ford Motorsport E3ZM-6015-A351 Block.
Post  Mark Miller May 2nd 2011, 1:25 am
A guy was asking on yellowbullet,i looked in some of my older Ford Racing Catalog but didn't find anything.
Thanks Mark.
Anyone know the specs of a Ford Motorsport E3ZM-6015-A351 Block. Empty Re: Anyone know the specs of a Ford Motorsport E3ZM-6015-A351 Block.
Post  Injected65 May 4th 2011, 11:25 am
The A351 was the "sportsman" block. 2-bolt mains. They had several casting runs on this block. Early on they were a heavier duty casting worthy of the SVO name. In the middle Ford swapped over to a lighter casting not much different than a stock 351WE block. Then late in the production they went back to the heavier blocks. You can usually tell by looking at the main saddles. The heavy duty blocks had smooth, thick machined saddles. The lighter blocks had the sculpted, hollowed out main saddles and weren't appreciably stronger than the factory blocks.
Injected65
Injected65
http://www.innovatorswest.com
Post  Mark Miller May 5th 2011, 12:49 am
I believe the 6010-A351 Was the Sportsman block he said it was a 6015-A351 and said it was a 4 bolt main block.
Thanks Mark.
Post  Injected65 May 5th 2011, 12:51 pm
Sorry about that. I assumed the 6015 was a typo. I have every Motorsport book back through 1994 here (except for 98, 99 and 01) and all blocks are 6010 numbers and the only A351 block is the 2 bolt Sportsman block (shows up in the 1997 catalog). I have seen people convert the heavy A351 block to 4 bolts though.
Injected65
Injected65
Post  DanH May 5th 2011, 1:38 pm
M-6010-A351 9.500 deck ht. , .060" over bore capability. Cleveland main size , 4 bolt main . this is for mid 1980's blocks . forgot , thought all Ford blocks basic number is 6010
DanH
Post  Mark Miller May 5th 2011, 11:45 pm
DanH,Thanks i'll ask the guy if the first 4 numbers are 6010 instead of 6015.
Thanks Mark.
