Crank pulley needed
Crank pulley needed
for a BBF, Fluidampr balancer, 3 bolt set up, center hole needs to be at least 2 3/8", the center to center bolt hole measurement is 3".
PM me or call Mike at 248-495-4023 for a quicker response.
Re: Crank pulley needed
I'll look and see what I got. I have several, but they may all be 4 hole. If I have one you can have it for the cost of shipping.
ThndrChkn- Posts : 2216
Sorry man, all of mine are 4 bolt pattern.
ThndrChkn wrote:Sorry man, all of mine are 4 bolt pattern.
Thnx for looking Doug
crank pulley
I will check my pile tonight i think i can set you up curt.
c-main- Posts : 39
3 Hole is FE? I don't remember.
Serpentine or V-belt?
D. Sea- Posts : 2768
D. Sea wrote:3 Hole is FE? I don't remember.
Dampner came from Blake. I believe he told me he had it on his car and we kinda thought it has possibly a gm bolt pattern, really don't care if its for an FE, gm whatever just as long as I can find one to bolt on the dampner to run an alt.
V-belt
I'm using a Serpentine pulley from a SBF but I think it's 4 hole
I have what you need.
It is an aluminum pulley with twin v-belt grooves, 6.610" diameter with a 3-bolt Chevy pattern.
The center hole is currently 2.035" and has plenty of material to make 2-3/8" with a quick trip to the lathe.
This is a modified "Chevy" aftermarket pulley that I used on a BHJ balancer that had a 3-bolt Chev pattern but had a Ford center register.
Give me a call and we can talk about the details. 678-458-2033
I will take it to work with me tomorrow in case you want it. I can customize the center hole size and ship it from there. I will need a dead-nuts size for your center hole, since that needs to pilot the pulley for a "no wobble" installation. If it has a BBF register pilot (snout), it should be 2.180" to 2.182" or so....
Keith
Keith
Wheelie58 wrote:I have what you need.
Keith
Thanks Keith I recieved the tracking number. I'll let you know how it goes.
Good Luck this weekend.........oh yeah and get some sleep
bigblockfox468 wrote:Wheelie58 wrote:I have what you need.
Keith
I hope it gives you something to work with.
Sleep....well....that stuff is highly overrated! I will get some rest when I get to the track tomorrow night.
Thanks,
Keith
» Crank Pulley Needed
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» crank pulley and alternator/fan/pulley options?
» aluminum crank pulley and a crank trigger
» Bed Lift for my trailer
