Southern Nationals - Super Gas 58 Ford Report
knrclark
Wheelie58
Southern Nationals - Super Gas 58 Ford Report Empty Southern Nationals - Super Gas 58 Ford Report
Post  Wheelie58 May 15th 2011, 11:39 am
Just got home from Atlanta Dragway from a less than perfect performance in Super Gas at the Southern Nationals. My previous 10.0 Index (no electronics) setup was pretty good, or at least I thought it was...so I used that to set up for the 9.90 class index. My first time run was a 9.85 at 142, and I was OK with that, considering that most of the "hitters" were way slow on that pass, may running in the 10.00 range. I adjusted the timing retards and ballast to slow the car down to hit the 9.90 deal, but was surprised with a 9.80! The car experienced a very slight wheel spin in the mid part of low gear and it made it pick up acceleration drastically in that segment.
Round 1 the next morning, retarded the timing even more, because the air was much better. My prediction/weather software was calling for a 9.77. I lined up with one of the best Super gas racers in the country who can run 9.90 at well over 160 MPH. I figured that he would be at my door at 900 ft...and when he was not, assumed that I must be set up "fast" and running under the 9.90 index. He got up even with my door as I approached the 1100 ft area, and then dumped me. I rolled thru at 9.76 at almost 143 Shocked and he won the double break-out deal with a 9.87.
So...back to the drawing board. I have some new thoughts and strategies to plug into the '58 for next weekend's Lucas Oil race at Altanta, where I will double enter in Super Gas and the 10.0 no-electronics index.
Super Gas is NOT the ideal class for the old '58. The class allows cars to be at 2100#, and I am about 1650# heavier than all of the other cars. Since it is so close to the 10.0 index, I will give it another shot anyway.
At least the 605 and the "2-speed non-Ford racing transmission" are healthy and happy and ready to rock once more.
Keith
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Southern Nationals - Super Gas 58 Ford Report Empty Maybe next time
Post  knrclark May 15th 2011, 11:56 am
Better luck next time Keith. Go get'em.
Kerry
knrclark
knrclark
Southern Nationals - Super Gas 58 Ford Report Empty Re: Southern Nationals - Super Gas 58 Ford Report
Post  bbf-falcon May 15th 2011, 7:56 pm
Early in the season Keith Shocked
Post  cool40 May 15th 2011, 8:04 pm
hay,it's runnen good and aint broke! sunny
Post  95lightiningguy May 15th 2011, 8:41 pm
Keep this up and you will run 8's before you know it. affraid lol!
95lightiningguy
95lightiningguy
Post  D. Sea May 16th 2011, 12:26 pm
Sure is making power!
I have the same issue Keith, when I try to slow my car down it 'resists' What a Face
D. Sea
D. Sea
Post  665 falcon May 17th 2011, 7:42 pm
Wheelie58 wrote:Just got home from Atlanta Dragway from a less than perfect performance in Super Gas at the Southern Nationals. My previous 10.0 Index (no electronics) setup was pretty good, or at least I thought it was...so I used that to set up for the 9.90 class index. My first time run was a 9.85 at 142, and I was OK with that, considering that most of the "hitters" were way slow on that pass, may running in the 10.00 range. I adjusted the timing retards and ballast to slow the car down to hit the 9.90 deal, but was surprised with a 9.80! The car experienced a very slight wheel spin in the mid part of low gear and it made it pick up acceleration drastically in that segment.
Keith
Keith i can tell you this, 9.85 @ 142.... is pretty Dam impressive, at that wieght... That 605 is working (HARD) and doing it's job Cool Cool Cool Cool
665 falcon
665 falcon
Post  Wheelie58 May 17th 2011, 8:47 pm
Thanks for the support guys.
The old car is just about ready to go in the trailer and head out to the next Lucas Oil race this week. I just installed my prototype trans pan chiller in the 2-speed to help cool the fluid between runs, since I will double enter the Super Gas and 10.0 index classes. It will allow me to circulate cold water through my trans pan while I log in the run and fuel the car for the next run.
I decided on a different tune up for this 10.0 deal. It is real hard to slow one of these things down a whole second. It may take a slightly smaller restrictor plate for the Flying Toilets, too.
So....here we go again!
Gotta go wear out the practice tree........
Thanks,
Keith
Wheelie58
Wheelie58
Southern Nationals - Super Gas 58 Ford Report Empty good luck
Post  knrclark May 18th 2011, 12:01 am
Good luck Keith I hope you have a great weekend.
Kerry
knrclark
knrclark
