pics from work 9-2-09
racnrick
pipedobber
pics from work 9-2-09 Empty pics from work 9-2-09
Post  pipedobber September 7th 2009, 10:32 pm
Just a few pics from work. Hot tapped a 12" natural gas line w/ 430 lbs on it, moving 18 million. I'm the fat one wearing the green cap. Chrispics from work 9-2-09 Photo4pics from work 9-2-09 Photo2pics from work 9-2-09 Photo1pics from work 9-2-09 Photo
pipedobber
pics from work 9-2-09 Empty Re: pics from work 9-2-09
Post  schmitty September 7th 2009, 11:04 pm
I'm betting that will stand your hair up a little. Shocked
Post  pipedobber September 7th 2009, 11:19 pm
Yea Schmitty, it had my full attention. I made the actual "hot" weld and the other welder helping me helped weld up the reinforcement tee. The wall thickness on the 12" was metered at .219". The things a guy will do for a dollar. Chris
pipedobber
Post  racnrick September 7th 2009, 11:28 pm
Cool, but Oklahoma doesn't require a metal box or bell around you when down in a pit? Maybe it's not that deep. I lost a good friend and Outlaw Late Model dirt racer Bob Shyrock, years ago in that same situation. It was a freak accident, and should have never happened to him. He was a backhoe operator for a company that was replacing old pipes in Minneapolis-St Paul. It was a Friday afternoon and their welder had went home early that day, and someone noticed that it needed more welding, being Friday afternoon and they needed to finish this before going home, Bob said he would weld it so they could be done faster than to wait for another welder to come. They had a bell there to use, but he didn't want to mess with it to save time. He had finished welding and was ready to come out when it caved in on him, he seen it coming and dove down and stuck his head in an old open sewer pipe before it covered him up. They could talk to him thru a manhole, and immediately started digging him out, he could tell them when he felt the pressure of the backhoe bucket getting close to him, when the pressure of the dirt lightened up enough for him to wiggle free he pulled his head out of the pipe and stood up, but it then caved in a second time and with the dirt covering the pipe opening he had nowhere to go that time, by the time they hand dug down to him he had suffocated. Just remember it only takes a second for an accident to happen.
racnrick
Post  pipedobber September 8th 2009, 7:45 am
Rick, it's always in the back of my mind. It was pretty hard dirt there, even though it was wet. You can't really tell from the pics, but it is benched pretty well. I went to excavating school a couple years back, all day class, and you learn alot about the excavating. I always tell the operators when they are done digging, lay under the pipe and look up at the ground and see if they feel safe. It can be a bad deal and it only take a split second. Chris
pipedobber
Post  Old blue Racin Team September 8th 2009, 7:51 am
Looks fun man pics from work 9-2-09 Icon_lol pics from work 9-2-09 Icon_biggrin
Old blue Racin Team
Old blue Racin Team
Post  Greg_P September 8th 2009, 10:43 am
Forgive my ignorance, but does Hot Tap mean that the pipe's pressureized and flowing gas while you're welding on it?
Shocked
Greg_P
Greg_P
Post  pipedobber September 8th 2009, 7:00 pm
Greg, yes the pipe was pressurized while I was welding on it. It had 430 psi and was moving 18 million through it. They brought the pressure and flowrate down because the pipe was so cold, it was sweating really bad. Chris
pipedobber
Post  Greg_P September 8th 2009, 8:28 pm
WOW, that's amazing.
How do they open up the "T" after you guys are done?
Greg
Greg_P
Greg_P
Post  pipedobber September 8th 2009, 9:00 pm
Greg, if you look at the "nipple" I welded on, after we welded the reinforcement tee on, we welded a flange on the nipple. Then a valve is bolted to the flange, close the valve and then on the other side of the valve, a big hydraulic machine is bolted to the valve. The valve is opened and the machine has a shaft and bit on it, like a huge holesaw and they drill the hole in the pipe. When the hole is drilled, they run the bit back out, close the valve, unbolt the machine. You now have the pressure against the valve, in this case, we fabbed an above ground valve setting and bolted to the valve. Once the above ground valve setting was in place, we opened the valve we hot tapped with, coated it, and buried it. Now the above ground valve is what they operate the new section of pipeline with. Chris
pipedobber
Post  Greg_P September 8th 2009, 9:25 pm
That is absolutely amazing. My hat's off to you, sir, for doing a kick ass job that I'd be too dam scared to do.
Twisted Evil Twisted Evil Twisted Evil
Greg_P
Greg_P
Post  pipedobber September 8th 2009, 9:34 pm
Thanks Greg, funny thing is that I'm too scared to fly in a plane but do this kind of work all the time. It's all what we are used to doing and what we understand how works. Chris
pipedobber
Post  the Coug September 8th 2009, 9:55 pm
Pipe dobber 18 mill is a spit in the bucket for me, most times I push 800 million to 1.5 billion @ 900 psi... and yes shoring is an art, and someone knows how to shore a bell hole is good to have on sight...... Nice to know someone else is in the oilfield trash business..... Very Happy
Post  pipedobber September 8th 2009, 10:04 pm
Randy, that's cool you're in this business also. What do you do? I don't know what the line normally runs, just that when they came out and d-metered the pipe, that is what they ended up bringing it down to. At first the pipe was moving a lot of gas and we had them bring it down as it was sweating too much to get a good weld on. I was a contract welder for Duke Energy later DCP, for 7 years and last nov. I went to work contract welding for OneOK. Chris
pipedobber
Post  jasonf September 8th 2009, 10:05 pm
I bet there is a lot of oilfield trash around here. I know I am.
pics from work 9-2-09 Oilfieldtrash-1
Post  pipedobber September 8th 2009, 10:09 pm
LOL, I was going through Woodward one morning a couple years ago. Pulled up to stoplight behind a brand new F-250 King Ranch, lifted, big tires and 20's with a huge sticker across the back glass "Oilfield Trash Part II".
pipedobber
