1977 Ford Bronco Parting Out! SOLD
1977 Ford Bronco Parting Out! SOLD Empty 1977 Ford Bronco Parting Out! SOLD
Post  prosandguy June 5th 2011, 10:48 pm
OK guys, I've decided its enough of the "family" vehicles and back to a serious race car, so the bronco is up for sale. 1977 Ford Bronco, 351W engine, full fiberglass body, PA c-4 with manual reverse pattern valve body and trans brake,0 miles on rebuild, Hurst Pro Ratchet shifter with air shifter setup too. New front and rear 5.13 gears, rear has new 31 spline axles and 31 spline spool. Also has aluminum radiator, CSR electric water pump, custom soft top, 3.5" James Duff lift, your choice of convertors- PA 9" 4500 stall or brand new Coan 10" 3500 stall, fuel cell, all braided lines, Aeromotive regulator with Holley fuel pump, 6 point chromoly cage, Optima yellow top battery. It has a clean MI title and VIN, even though I have only about 25 street miles on it, but its a blast to drive. You can sand/dirt drag it, run the dunes with it or street cruise it too. Currently set up for Ethanol, but with a carb change it will take pump gas. The 351 has forged TRW pistons, hyd roller cam, motorsport roller rockers, J302 heads by High Velocity Heads and matching Victor Jr intake. I just went thru it last winter(2010) and put 5 passes on it before I broke something in the trans, never drove it since.
Its been great for me, I just can't bear to cut it up to make a more serious sand drag car out of it.
Comes with 33x12.50 Baja claws on 15x10 chrome wagon wheels, or the sand tire setup-12.00 Desert Traks on 15x7 Centerline Convo Pros front and 20.00 STU paddles on 15x18 CMS wheels rear.
1977 Ford Bronco Parting Out! SOLD 100_1585
Alright, since no body seems to want it whole, I'm gonna part it out. First come, first served.
Body, frame, axles, steering, ignition, title and VIN $5000
Trans, converter and transfer case $1300
351W engine, complete oil pan to carb $1700
Baja claws on rims $400
Everything is best offer, but the rolling chassis needs to go first. I'll even help with delivery or shipping if somebody is interested, and I'll deal if you want more than one thing.
prosandguy
prosandguy
1977 Ford Bronco Parting Out! SOLD Empty Bronco
Post  HELI-ARC June 9th 2011, 7:11 am
Hey there anouncer guy - Sent ya a pm
HELI-ARC
1977 Ford Bronco Parting Out! SOLD Empty Re: 1977 Ford Bronco Parting Out! SOLD
Post  Motorhead79 June 13th 2011, 8:49 pm
give me call if u still have bronco ,thxs 618 779 2866
Motorhead79
Post  prosandguy June 25th 2011, 9:08 am
Bump for the part out.
prosandguy
prosandguy
Post  738drvr June 26th 2011, 12:37 am
Pm sent
Post  prosandguy June 26th 2011, 6:35 pm
PM returned
prosandguy
prosandguy
Post  t120r June 28th 2011, 9:40 pm
Last september I would have bought the whole thing. Ah well.
t120r
Post  prosandguy June 28th 2011, 10:18 pm
Sale Pending!!
prosandguy
prosandguy
