tire size and et
johndickjr
tire size and et  Empty tire size and et
Post  johndickjr June 10th 2011, 3:42 pm
will a car be faster with a taller tire compared to a shorter tire, if the gears are changed to put the motor in the same rpm range as the other...say your car cross the line at 6500 rpm with a 4.56 gear and 31 inch tires...and you change tires to a 28 inch tire and 3.73 gears,,<----just a compression . , with the same rpm at the line only difference is tire diameter
johndickjr
tire size and et  Empty Re: tire size and et
Post  richter69 June 10th 2011, 3:59 pm
bigger tire can add drag and slow it down, on the other hand the smaller tire can spin easier and slow it down.
I'd go with the bigger tire option myself.
Post  johndickjr June 10th 2011, 4:08 pm
ok, i was thinking someone had said something about the roll out of a larger tire and the foot print ..etc..etc..my new car has 31x10.5w tires but with 3.73 gears ...i can put my 4.56 in or swap to a smaller tire or both, right now i have a small block that's pretty nasty, with the 4.56 gears and 31 tire will put me right where i want to be, i was unsure if that is the way to go or just leave the 3.73 in there and put some 26-28 inch tires on..thanks
johndickjr
Post  richter69 June 10th 2011, 4:57 pm
Change the gear.
Post  69F100 June 10th 2011, 5:04 pm
Mine has a 4.89 gear with 31x10.5Ws with a bbf in the 1/8 I cross the line at 6000 rpm at 7.12 et but this is a mild built engine .
Jim
Post  cool40 June 10th 2011, 10:21 pm
if the car has the 3.73 gear in it now,i'd try it just to see what it would do but i'm real bad about changing stuff too much.lol
Post  johndickjr June 12th 2011, 2:01 pm
decide to change the gears out for some 4.56 with a 31 inch tire
johndickjr
Post  psfracer June 14th 2011, 2:09 am
I guess the question would be can you hook on a 28 tall tire? As long as you are not running a large tire size that you don't need, I was always taught to go with the larger tire, then gear accordingly to maximize the contact patch. BUT--if you would hook fine on a 28X10.5 lets say, then no need to go with the larger, heavier tire.
psfracer
psfracer
http://www.psfracer.com
Post  dfree383 June 14th 2011, 8:50 am
Bigger tires tend to be more consistant
Post  johndickjr June 14th 2011, 11:24 am
reason it has 3.73 is it had a BBC in it before i got it was running 8.90's i putting a small block in it for now and i have a set of 4.56 already and the tires on car have 3 passes on them , thanks
johndickjr
