Fuel Line ?
hillbillyerv
Fuel Line ? Empty Fuel Line ?
Post  hillbillyerv June 17th 2011, 11:01 am
can a guy use 1/2 in. alum tube for fuel line with race gas?? instead of steal or braided?
thanks Erv.
hillbillyerv
hillbillyerv
Fuel Line ? Empty Re: Fuel Line ?
Post  cool40 June 17th 2011, 11:05 am
yes,i did for years before i put the front cell in my car.it came from jegs,was blue,and i think it was Russell brand but any should work fine. Very Happy
Post  hillbillyerv June 17th 2011, 11:15 am
thanks, cool40 for the input Cool
hillbillyerv
hillbillyerv
Post  lghting94 June 17th 2011, 12:50 pm
I ran 1/2 aluminum line on my mud truck for 5 years and never had an issues just use flex lines between the pump/tank and where it mounts to the chassis, and also from the chassis to the engine.
lghting94
lghting94
Post  Barney June 17th 2011, 12:53 pm
lghting94 wrote:I ran 1/2 aluminum line on my mud truck for 5 years and never had an issues just use flex lines between the pump/tank and where it mounts to the chassis, and also from the chassis to the engine.
X2 its cheaper, lasts longer, lighter, and flows better than braided.
Barney
Barney
Post  Wheelie58 June 18th 2011, 6:19 am
Like the others say....
I had this setup on the '58 for several years, 1/2" aluminum line, and used bulkhead fittings with welded frame tabs on both ends to support where it changed to AN for flex connections. Just make sure it is well supported with cushioned "P"-clamps and that nothing touches it (that moves). It will not tolerate abrasion and flexing will eventually kill it (the tubing).
In my opinion, with gas and carb, it is not a bad deal. Just price all of the fittings in advance to see the real value of the deal.
Have fun...
Keith
Wheelie58
Wheelie58
Post  512Fairlane June 19th 2011, 7:35 pm
I've been running aluminum 1/2" line for the last 15 years without any issues. I run short lengths of braided line at each end and use good clamps all the way along the line.
512Fairlane
512Fairlane
