10.17 @ 137.66
+13
dr's wife racing
QtrWarrior
BigDave65
'65 T-BOLT
bosshoss
Race Ready Fabrications
bigblockfox468
17 posters
10.17 @ 137.66 Empty 10.17 @ 137.66
Post  bigblockfox468 June 27th 2011, 12:36 pm
Well I FINALLY got out to do some shakedown passes. Went to Lapeer Dragway yesterday. I did 5 passes. The right lane was better than the left lane.The second pass I let er rip the full 1/4, I was in the right lane. The 3rd pass I was in the tower (left) lane and had to get out of it between the 1/8th and the 1/4. The car got squirrelly and THAT was an experience Shocked On the second pass it wandered then too but not as bad. So I only did 1/8 after that. It does do some wandering before the 1/8th but is controllable. However I don't like that wandering crap. Not sure why I have this now. The tires are about 2 years old. They are Hoosier Quick Time Pro's 28X11.50X15's. I ran 12 lbs in them yesterday. I've ran that psi before with these and it seemed fine. I would've like to let a little more air out to see if I could better my 60' times but was afraid to because of the wandering. I lowered my shift rpms from 6300 to 5000. That seem to help out on the tire spin. So I plan on getting a regular drag slick now.
I tried to post an et slip but for some reason photobucket won't upload it but I was able to upload a video.
My 60' times ranged from 1.55 to 1.65. my 1/8 times were 6.63-6.66 @ 107.78 mph.
10.17 @ 137.66 Th_IMG_0170
10.17 @ 137.66 Th_IMG_0176
bigblockfox468
bigblockfox468
10.17 @ 137.66 Empty Re: 10.17 @ 137.66
Post  dfree383 June 27th 2011, 12:58 pm
sounds like your going to be working on the suspension now !!!
Post  bigblockfox468 June 27th 2011, 1:49 pm
Here's the 1/4 mile ET slip.
10.17 @ 137.66 Timeslip002
bigblockfox468
bigblockfox468
Post  rmcomprandy June 27th 2011, 2:03 pm
137+ MPH is mid to high nines speed so, I would say the car combination needs to get "worked out" some.
You'll get there eventually.
Post  Race Ready Fabrications June 27th 2011, 2:43 pm
Mph definitely shows you got the power...just gotta get it off the line! You leaving off the foot brake or transbrake? Stock suspension or ladder bars? A 'real' slick will definitely help IMO.
Post  IDT-572 June 27th 2011, 2:46 pm
at 3000 lbs, 6 teens or twenty's 1/8th mile and 9.50's 1/4 mile, when you get all the bugs out and hooking.............. Cool
Could see some 0's in mine shaft air and a bitin track.
Does it weigh more than 3000lb?
Hurry up and get some new shoes on that heifer.............. lol!
Post  bigblockfox468 June 27th 2011, 2:59 pm
Race Ready Fabrications wrote:Mph definitely shows you got the power...just gotta get it off the line! You leaving off the foot brake or transbrake? Stock suspension or ladder bars? A 'real' slick will definitely help IMO.
Foot braking. I wanted to try the transbrake but didn't. I had my hands full with the wandering bit. Stock suspension set up with an anti roll, adjustable upper Edelbrock control arms and some HPM lowers, adjustable rear Competion Engineering shocks, some adjustable front coil overs. Don't know squat about them like brand, the setting etc. The car had all this stuff on it when I purchased it, so I don't know any particulars of what/how/why/where the settings are set to what they are. First thing I'm going to do is get some ET Drags on the rear and some drag front bias tires. It has radials on front now and with the Hoosier QTP's being bias that may be causing some wandering.
bigblockfox468
bigblockfox468
Post  bigblockfox468 June 27th 2011, 3:21 pm
IDT-572 wrote:at 3000 lbs, 6 teens or twenty's 1/8th mile and 9.50's 1/4 mile, when you get all the bugs out and hooking.............. Cool
Not sure of the weight right now. Before with the 468 D0VE headed engine, C-4, exhaust dumping at the rearend, center console, radio and heater control I weighed it at 3330 with me in it (I weigh 220) I have removed some lbs from the car since. Went to alum SCJ's, removed some interior, the exhaust, cut the motor mount set up and went to front and mid plates, installed a glide. If I had to guess I would say 150 lbs +. Planning on re-weighing hopefully this week.
bigblockfox468
bigblockfox468
Post  bosshoss June 27th 2011, 3:26 pm
Not enough toe in, Not enough caster, rear end misalignment and or stiffness/binding in the steering column are a few area's I know of that can cause the car to wander around.
dkp
bosshoss
bosshoss
Post  whatbumper June 27th 2011, 4:39 pm
Needs tires before anything.
Post  bigblockfox468 June 27th 2011, 4:44 pm
whatbumper wrote:Needs tires before anything.
10-4...........agreed..........thats the plan
bigblockfox468
bigblockfox468
Post  '65 T-BOLT June 27th 2011, 6:07 pm
congrats on getting it down the track!.like everyone said...figure out the suspension and it will be flying!
'65 T-BOLT
'65 T-BOLT
Post  BigDave65 June 27th 2011, 6:17 pm
bosshoss wrote:Not enough toe in, Not enough caster, rear end misalignment and or stiffness/binding in the steering column are a few area's I know of that can cause the car to wander around.
dkp
X2 definitely get the front end alignment checked!
BigDave65
BigDave65
Post  DILLIGASDAVE June 27th 2011, 8:23 pm
Along with getting real slicks & checking the front end alignment, also check the front suspension geometry for any possible bump-steer problems.
Post  QtrWarrior June 27th 2011, 8:31 pm
Is it possible that the wandering is actually wheelspin going down track ?? When we first started running Doug's car, we had a similiar issue.
QtrWarrior
QtrWarrior
Post  bigblockfox468 June 27th 2011, 9:28 pm
DILLIGASDAVE wrote:Along with getting real slicks & checking the front end alignment, also check the front suspension geometry for any possible bump-steer problems.
Will do............BUT I don't know how to do that (suspension geometry) scratch I may be hitting you up for guidence Wink
bigblockfox468
bigblockfox468
Post  bigblockfox468 June 27th 2011, 9:32 pm
QtrWarrior wrote:Is it possible that the wandering is actually wheelspin going down track ?? When we first started running Doug's car, we had a similiar issue.
Mike,
Blake and I discussed that possibility. What did you guys have to do to rectify that?
First step for me is to get some new rubber on the rear and the front and get the alignment checked.
I really do appreciate everyones input here. Thanks guys and keep it coming cheers
bigblockfox468
bigblockfox468
Post  Mark Miller June 27th 2011, 11:40 pm
The radials on the front and the bias ply Hoosiers on the back very well could be the problem.I had radials on the front of my car with MT Et streets on the rear and on some roads you could feel the rear of the car swaying back and forth some.I switched to the MT Bias Sportsman front tires and the swaying went away.
Later Mark.
Post  IDT-572 June 28th 2011, 12:48 am
Mark I told him the same thing this morning, I have had some cars that were undrivable because of that same deal................. Wink
Post  dr's wife racing June 28th 2011, 11:37 am
Do the things that ya'll discussed.Mine is back at the chassis shop Greg convinced me mine is missing a few key pieces and agood geometry work up.I'm no expert but I'll share with you if it works or not. PM me and I'll fill you in on my set up,and what he thinks are the missing links.Don't want to bore everybody here with it again. Really it's Top Secret Squirrel Crap and I don't want Bruno affraid to know before the Bash.I just kept beating my head aginst the wall,could get the car to drive but when I would try and pick it up a bit it would start acting up again.
dr's wife racing
dr's wife racing
Post  Mark Miller June 29th 2011, 12:06 am
IDT-572 wrote:Mark I told him the same thing this morning, I have had some cars that were undrivable because of that same deal................. Wink
Blake,i hear you kind of a uneasy feeling when you're only going 40 mph and you feel the rear of the car dancing around on you. Very Happy Very Happy Very Happy
Later Mark.
Post  bruno June 29th 2011, 9:21 am
ive got 2 sets of 3062s with only 12 passes on them if you need a set
http://WWW.CKRME.COM
Post  GTmustang July 1st 2011, 12:01 am
Take it to Milan, better track prep there. New bigger tires probably wouldn't hurt either. Glad to see it knocking on the door to the 9's. Is your car certified for the 9's?
Gary
GTmustang
Post  D. Sea July 13th 2011, 12:09 pm
At 137mph you have a LOT of ET left on the table. I agree a true race slick will help a bunch and once you get all the bugs worked out it should be a mid 9 second ride Cool
Congrats!
D. Sea
D. Sea
Post  GTmustang July 15th 2011, 10:32 am
D. Sea wrote:.... and once you get all the bugs worked out it should be a mid 9 second ride Cool
Congrats!
And then you put that NOS plate on with a 150 shot.........!
Gary
GTmustang
