3.73 gears
3.73 gears  Empty 3.73 gears
Post  Tennessee Bullitt June 27th 2011, 9:14 pm
I finally got back out to the track, I believe I am going to drop my rear gears due to some footbrake testing I did. I was coming up on the converter to 2,000 rpm's first run then to about 2,200 rpms on the second run and sure enough taking off dead idle at 1,200 rpms on the third run I did the best 60' time. My 60's in order was 1.45, 1.48, 1.42, and on the idle run I was 3 to 4 tenths faster down the track. I am also running through the gears really fast. My trans shifts so good it dosen't really loose a lot of rpm's. Shifting at 6,000 I will run into 3rd before the 1/8 mile trap.
Does it seem like droping the rear gear will be able to ride the torq more and pull harder as I go down the track? I tried to run a 6.60 for a declaired index race and I caught the truck at half track, bliped the throttle 3 times and coasted on through the traps without touching the brakes and here was the results for this pass which was taking off at idle....
60' 1.42
330' 4.1689
594' 6.0950
1/8 6.57
1/8 mph 94.42
The other passes netted two 6.54 passes, one of them at 105.75 and the second at 105.89.
Am I thinking correct on this idea?
Tennessee Bullitt
Tennessee Bullitt
3.73 gears  Empty Re: 3.73 gears
Post  Tennessee Bullitt June 28th 2011, 11:04 pm
Question Question Question Question
Tennessee Bullitt
Tennessee Bullitt
Post  cool40 June 28th 2011, 11:10 pm
what gear you runnen now?
Post  69F100 June 28th 2011, 11:14 pm
I have found leaving at idle mine make better 60' and better ets I am running 4.88 gears with 31x10.5w c6 trans crossing about 5800 99 to 100 mph
Post  Tennessee Bullitt June 29th 2011, 6:28 am
I am running the good ol 4.10 gears with 28 tall tires and C6 trans.
Tennessee Bullitt
Tennessee Bullitt
Post  dfree383 June 29th 2011, 8:12 am
What convertor are you running?
Post  cool40 June 29th 2011, 2:13 pm
your converter sounds loose to me if you into high gear fast and a 3.73 aint gona help that.
Post  Tennessee Bullitt July 3rd 2011, 10:09 pm
I have a spec built PTC converter, I mis caculated my weight by 300#'s. It's lighter than what I told them. The converter works, I can get into 3rd if I am shifting at 6,000. At BG last year I was hitting the 1000' mark I guess ther about when I was topped out. IT was not to far from the finish line.
Tennessee Bullitt
Tennessee Bullitt
