new crank!!
Wheelie58
bigblockfox468
new crank!!
My New Bryant Billet 5.300 stroke crank showed up today for my 712 !!!
sure is pretty!!!
sure is pretty!!!
Frank Merkl- Posts : 1524
Re: new crank!!
Yep its puuuuuuurrrrddy
res0rli9- BBF CONTRIBUTOR
Re: new crank!!
couldn't sleep !! had to go back to the shop and measure the crank and hang a rod and piston on it to see if my math was right !!! and it fits!!!!!!!!!!!!!!!!
Re: new crank!!
with a 5.300 stroke and a 4.625 bore and a 7.190 rod with a 1.350 compression height flat top piston with unmolested valve reliefs makes 14.5 -1 and I'd like to be 13.5 - 13.8 to 1 (some massaging on the Valve reliefs will get us there) for all the nitrous were going to throw( 4 -300hp kits) at this motor . it's sure as hell will make the car run !!!!! HARD in the top end!!!! 2250 hp will do that!!!
Re: new crank!!
Thats gona be a Bada Boy
Re: new crank!!
Frank Merkl wrote:with a 5.300 stroke and a 4.625 bore and a 7.190 rod with a 1.350 compression height flat top piston with unmolested valve reliefs makes 14.5 -1 and I'd like to be 13.5 - 13.8 to 1 (some massaging on the Valve reliefs will get us there) for all the nitrous were going to throw( 4 -300hp kits) at this motor . it's sure as hell will make the car run !!!!! HARD in the top end!!!! 2250 hp will do that!!!
Frank........you a wild man
Re: new crank!!
I can understand why you couldn't sleep !!! Thats a pretty Piece !!
Whats it weigh in at and How did it balance?
Re: new crank!!
You should charge people to look at the picture...and charge more...if they want to touch your crank.
That is very nice!
Keith
That is very nice!
Keith
Re: new crank!!
Nice crank Frank!! I'm just glad your good at math Your son had better be ready for the ride of his life!!There must be a really fast street car lurking around somewhere for you to build something like that
56Tbird- BBF CONTRIBUTOR
Re: new crank!!
Thats going to be one hell of a "Well Pump" Motor !!!
Re: new crank!!
NICE !!!!
cletus66- Posts : 865
Re: new crank!!
Just like a kid with a Christmas present, they have to play with it all night long. I think you are going to give them guys with the Leonard engines a handful when you light that thing up.
schmitty- Posts : 4538
Re: new crank!!
that's my intention Schmitty , this Bad boy should run Hard!!!! Kaase said it my be a tad hard on valve springs with the 1.060 lift cam thou!!
Re: new crank!!
thanks Frank! now i know why it's took so long to get my little 4.5 stroke! i'd sleep good if i had that crank,it'd be in bed with me!
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» aluminum crank pulley and a crank trigger
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
» Looking to trade a BBF MSD crank trigger for a SBF crank trigger
