Found some bent valves...
Found some bent valves... Empty Found some bent valves...
Post  jbozzelle July 2nd 2011, 7:01 pm
Damn wreck in the dragster took out 2 valves too! Just tore the engine down and found the intake and exhaust valves on cylinder #8 bent. The intake just barely missed the seat on one small spot when I mark it and spin it to check contact. The exhaust is clearly bent!
Hopefully that's all as I dig into it some more. I'm going to pull that rod car and see if the bearing looks OK.
Lem, you got some valves in stock?
Found some bent valves... Empty Re: Found some bent valves...
Post  Lem Evans July 2nd 2011, 7:27 pm
Yes sir.
Post  jasonf July 2nd 2011, 9:00 pm
Bumber sorry to hear that john. U cant catch a break.
Post  IDT-572 July 2nd 2011, 9:46 pm
Check everything close John...............
Post  jbozzelle July 2nd 2011, 10:10 pm
Lem, I'll call you Tuesday.
I also found the 2 roller rockers beat up on the roller tip and the studs have some scoring too. I figure I'll replace the rocker and studs too.
The rod bearing looked fine though.
Post  Lem Evans July 2nd 2011, 10:12 pm
Cool
