Are main stud girdles really a waste of money??
bigunitmudracing
Are main stud girdles really a waste of money?? Empty Are main stud girdles really a waste of money??
Post  bigunitmudracing July 8th 2011, 12:46 pm
are main stud girdles really a waste of money??
Should i use stock main cap bolts or arp main cap bolts?? race engine
thanks
bigunitmudracing
bigunitmudracing
Are main stud girdles really a waste of money?? Empty Re: Are main stud girdles really a waste of money??
Post  rmcomprandy July 8th 2011, 1:56 pm
It all depends ... IF the girdle is a MAIN CAP supporter and not simply a FASTENER supporter, then it might be worth the money if the maximum torque the engine will produce dictates it.
MOST, (but not all), main girdles in the marketplace do not fit into those parameters.
Post  bigunitmudracing July 8th 2011, 4:25 pm
On a 600 hp motor is it something you would use?
or do you need to 4 bolt main the block at that hp.?
Or is the stock setup perfect and dont mess with it?
bigunitmudracing
bigunitmudracing
Post  69F100 July 8th 2011, 5:09 pm
bigunitmudracing wrote:On a 600 hp motor is it something you would use?
On mine I have a stockd9 block with stock mains,stock crank with close to that hp level and don't have any trouble with the bottom end turn it 6500 rpms
Post  rmcomprandy July 8th 2011, 7:49 pm
If you canvas a hundred people, there will be SOME who will answer you with the answer you think you should be getting, lol.
Especially those who use Small Block Fords.
Post  bigunitmudracing July 8th 2011, 9:27 pm
well i'll just stick with the 2 bolt mains and stock bolts.. because it will do its job perfectly!!!!
bigunitmudracing
bigunitmudracing
Post  cooter July 8th 2011, 11:23 pm
just make sure to keep it out of detonation or with girdle or without girdle you will have main problems
cooter
Post  richter69 July 8th 2011, 11:31 pm
we run smallblock fords too............you dont "need" to spend money on a girdle lol. We dont run one on our 550 hp stock block 5.0.........the block will split in half long before the mains give way lol.
Post  cool40 July 9th 2011, 1:39 am
i run a d0ve 2 bolt block with arp studs.dont know the hp but it's been goen 5.40's in my 2600#car.
