Say it ain't so!
+8
72mav
BigDave65
56Tbird
12 posters
Say it ain't so! Empty Say it ain't so!
Post  67460 July 10th 2011, 11:52 am
Work all week getting car ready for the 2nd trip to the track with my new 557 engine.
It is sounding and running great! Going back for tnt.
The last thing I had to do is check valve lash again. Check passenger side out ok.
Pull driver side and notice a small pin lying on top of the head, look futher and found one side of the
rocker bearing retainer cup too, and it was empty, where are all the other little pins from my crane gold rockers.
Only one side of the rocker lost its pins. Man I am petty down about this, Say It Ain't So!
I did change the old and I did fine about 2 of them so now thats 3 of 30.
I still have the old filter will be cutting it open today! What a stomach ache.
Just thought I talk about it.
67460
67460
Say it ain't so! Empty Re: Say it ain't so!
Post  Lem Evans July 10th 2011, 12:00 pm
Are they the ones w/o the retaining clips on the end of the shaft?
Post  56Tbird July 10th 2011, 12:04 pm
Melvin ,take a piece of wire with a magnet on the end of it. Stick it in your drain hole and run the wire around. The pins have to be in the pan. They're too big to go through your screen on your oil sump. Good luck...It sounds like you can sure use some!!
56Tbird
56Tbird
Post  67460 July 10th 2011, 12:08 pm
[img]Say it ain't so! RockerArm[/img]
This is it.
67460
67460
Post  67460 July 10th 2011, 12:09 pm
Thanks 56 bird,
67460
67460
Post  BOSS 429 July 10th 2011, 12:11 pm
^ yes,and spray some brake clean down the oil return holes to losen up sticky ones,and tap pan with a rubber hammer while tryin to find them,have you found any broken ones?
Post  67460 July 10th 2011, 12:16 pm
BOSS 429 wrote:^ yes,and spray some brake clean down the oil return holes to losen up sticky ones,and tap pan with a rubber hammer while tryin to find them,have you found any broken ones?
No broken ones yet, Will do!
67460
67460
Post  67460 July 10th 2011, 12:30 pm
Lem Evans wrote:Are they the ones w/o the retaining clips on the end of the shaft?
Yes!
67460
67460
Post  Lem Evans July 10th 2011, 1:27 pm
Get them off the engine. Sooner or later others will have the cracked/split bearing cage. The Crane gold and FRRP blue [crane also] with the retainer clips are good rockers.
Post  67460 July 10th 2011, 2:25 pm
Lem Evans wrote:Get them off the engine. Sooner or later others will have the cracked/split bearing cage. The Crane gold and FRRP blue [crane also] with the retainer clips are good rockers.
Done!
67460
67460
Post  BigDave65 July 10th 2011, 2:30 pm
I had the very same thing happen on a 351-c with the crane gold rockers, but they were some old NASCAR take offs. I think it's just a fatigue thing. I still run the Crane golds.
BigDave65
BigDave65
Post  67460 July 10th 2011, 2:32 pm
So Far everything is looking petty good, open oil filter and no bearing pins in it.
Checking oil pan so far nothing. Could have fell out in last engine build scratch
67460
67460
Post  the Coug July 10th 2011, 2:34 pm
67460 wrote:So Far everything is looking petty good, open oil filter and no bearing pins in it.
Melvin there will not be any pins in the oil filter if so the Pump will be shot!!!!!!!!!!! the pins will not go thru the pump if they do it will wipe out the rotors......
Post  BOSS 429 July 10th 2011, 2:40 pm
right thats why i said cut the filter, ive seen them make it thru to the filter in small parts,thus hurting the pump
Post  67460 July 10th 2011, 2:41 pm
I'm sure glad of that.
67460
67460
Post  Lem Evans July 10th 2011, 2:52 pm
If the pan is off it'd be a simple matter to inspect the internals of the oil pump.
Post  67460 July 12th 2011, 12:40 am
Pull engine and found the little guys,
REAR SUMP
[img]Say it ain't so! DSC00074[/img]
FRONT SUMP
[img]Say it ain't so! DSC00072[/img]
67460
67460
Post  BOSS 429 July 12th 2011, 12:55 am
DID YOU GET NEW ROCKERS YET?
Post  67460 July 12th 2011, 1:32 am
BOSS 429 wrote:DID YOU GET NEW ROCKERS YET?
They should arive in a day or two, went with crowers stainless.
67460
67460
Post  56Tbird July 12th 2011, 7:28 am
What a PITA for a piece of junk rocker!! But at least you know your engine is well!! king
56Tbird
56Tbird
Post  dfree383 July 12th 2011, 7:44 am
Yea, better to take it apart and check than not know.
Post  67460 July 12th 2011, 9:31 am
For sure, didn't want to do it but glad I did, Very Happy
by 56Tbird on July 12th 2011, 6:28 am
dfree383 wrote:Yea, better to take it apart and check than not know.
67460
67460
Post  72mav July 12th 2011, 5:36 pm
Your luck is improving Melvin!
Sorry to see this happen though. Glad you caught it.
Regards.
Al
72mav
72mav
Post  schmitty July 12th 2011, 6:05 pm
Melvin you won't regret it. I had a set on the last engine and they were a work of art, and like Randy M told me "You can put them in the will for the grandkids". I know Lem has used more than a few sets too and speaks quite highly of them.
Post  maverick July 12th 2011, 6:18 pm
Glad you found 'em OK. Just FYI, next time any steel parts fall into the pan, just use a fairly strong magnet....stick it to the underside of the pan and drag it toward the drain plug hole, then pull it away. The steel parts will follow the magnet to the hole. If you carefully "cover" the entire bottom of the pan, you may find all your junk without a teardown. Wink
