Ladder Bar Adj.
Ladder Bar Adj. Empty Ladder Bar Adj.
Post  Tore July 15th 2011, 7:15 am
If I want to reduce the shock to the tires do I raise them or lower them?
Thanks Tore
Tore
Tore
Ladder Bar Adj. Empty Re: Ladder Bar Adj.
Post  cool40 July 15th 2011, 4:40 pm
you can lower them but it wont help much.shocks are the best way to slow the hit.
Post  DILLIGASDAVE July 15th 2011, 5:42 pm
To calm the initial hit down some first try adjusting rear shock extension valving tighter & tighter each pass. Then if you end up running out of shock adjustment (finally reach at/close to full-tight) but the car still needs a calmer hit, that's when you try moving the ladder bar down a hole. At this point you also back the shock valving back down some (looser) & start the shock testing over again in the new lower front hole.
Post  Tore July 15th 2011, 9:10 pm
Thanks Guys,
Tore
Tore
Tore
