Ugly engine at Phillip's
+13
patfromjersey
QtrWarrior
'65 T-BOLT
Wheelie58
17 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Re: Ugly engine at Phillip's
Jeez Lem ... is that the engine you had put together for Morgan's dragster...?
No it's not but you can see it in the back ground next to the wall.....pic. #2.
OK , I'll take it. Just send it to me. You have my address!
Nevs- BBF CONTRIBUTOR
Ugly ? It's a ford, whatcha expect lol
Looks good Lem, can't wait too see the numbers it puts up.
A big thanks to Lem and Phillip on this.
It's gonna look better after Mark gets it in the car.
-John
-John
John Myrick- BBF CONTRIBUTOR
O.........i thought it must'a had one of them ugly super size HeRo oil pans on it.
Dang, for a second there, I thought I was going to see another engine Phillip is working on . That one still looks sweet!
and .......................
Should be on the dyno soon
looks like an identical twin to mine!..from valve covers to pan!....but I know it has a lot more power
'65 T-BOLT- Posts : 1464
'65 T-BOLT wrote:looks like an identical twin to mine!..from valve covers to pan!....but I know it has a lot more power
Just never know
What's your numbers ?
-John
no numbers! I have 10.5 comp,Kasse fully ported SCJ's, Lem's special cam...just going on looks, 521 pump gas streetable engine.jjmstang wrote:'65 T-BOLT wrote:looks like an identical twin to mine!..from valve covers to pan!....but I know it has a lot more power
Just never know
-John
557 pump gas, Lem cam, Mafia intake, 1050 QF carb, SCJ's worked on by Phillip Oakley
Was made for street/strip
Lem can add more to this if he wants too
-John
-John
Good things come to those who wait
Doug Rahn wrote:bruno wrote:and .......................
He could tell, But then I would have to kill him! lol
QtrWarrior- Posts : 2703
QtrWarrior wrote:Doug Rahn wrote:bruno wrote:and .......................
Being dyno'd friday or saturday
Results to come
Results to come
rmcomprandy wrote:Jeez Lem ... is that the engine you had put together for Morgan's dragster...?
Now that i think about it...maybe it'd be a time to do the two engines back to back
After the 547" SCJ thing ran as quick as 4.89 last fall persons were throwing numbers around 850 - 900 HP........which I do not believe.
Unported FRPP SCJ and a gasket matched Victor.......I suspect a little over 800 hp....we shall see. It's just a thing that wants to run
hell.........no more time than you spend at work you should get it done.Lem Evans wrote:rmcomprandy wrote:Jeez Lem ... is that the engine you had put together for Morgan's dragster...?
\cool40 wrote:hell.........no more time than you spend at work you should get it done.Lem Evans wrote:rmcomprandy wrote:Jeez Lem ... is that the engine you had put together for Morgan's dragster...?
I spend most of my time on hold while people look for their flow numbers
Just received the dyno sheet and pics from Lem but I can't post them. Hopefully Lem can.
717 tq @4600/4700
700 hp @ 6000
557 pump gas
A460 block
SCJB's
Scat forged crank/rods
Diamond pistons
1050 QF carb
TFS mafia intake
Lem special solid roller cam
This not a balls to walls build as it is a street/strip car for the next 3 years. I used forged bottom end for the future ( alky or turbo )
Should be a hand full on the street
Thanks to Lem, Oakley and the crew at Automotive Machine and Performance.
-John Myrick
717 tq @4600/4700
700 hp @ 6000
557 pump gas
A460 block
SCJB's
Diamond pistons
1050 QF carb
TFS mafia intake
-John Myrick
The timing info is incorrect.....it's 32* not 34*.
» The good....the bad.....the ugly!!!!!!****Updated with Pics****
» Mike Phillips of Automotive Machine & Performance charged with aiding and abetting
» PHILLIPS RESPONSE TO NEW CLASS AT BASH
» The 2015 F150's are ugly....
» Good show on Mike Phillips shop
Page 1 of 3
